    Programming microcontroller on Application Board 2.0 for BMI085
    Samboff
    Dear Community,
    I am working with the BMI085 Shuttle Board and the Application Board 2.0. I wanted to connect an SD Card to the Application to be able to save the data from the BMI085 without having to have it connected to a computer per USB. Therefore I need to programm the MCU so that it knows to save the data onto the SD Card. To write the programm, I am using Atmel Studio 7.0. However, Atmel Studio does not recognize the Application Board when it is connected via USB.
    I was therefore wondering wether I need a different connection / board to Programm the MCU?
    Thank you in advance 🙂
    Sam
    jabezwinston
    You can use the standalone  app20-flash command line tool found in COINES to  program the Application Board 2.0 MCU.
    But the board to bootloader mode by powering on with button-2/switch-2 pressed. Pass binary file command line argument.
    Application flash memory starts at 0x410000 and hence adjust linker script settings accordingly.
    Linker script, app20-flash tool, sample binary can be found in program_app20_board.zip
    C:\COINES\v2.2\examples\c\bmi08x\read_sensor_data>app20-flash bmi08x_read_sensor_data.bin
    Application Board 2.0 firmware flash tool
    Bosch Sensortec GmbH (C) 2019
    APP2.0 detected.
    Download  [=========================]  100 %
    Download complete !
