    [Question] BMI270 : BMI2_E_CONFIG_LOAD
    Hugh
    I'm using STM32L4 MCU (STM32L476G-EVAL) and BMI270 shuttle board.
    Sometimes it works but mostly it fails to initialize. So I'm asking for your help.
    My setting is as follows:
    1. SPI 4-wire mode (STM32Cube_FW_L4_V1.16.0)
    SPI_HandleTypeDef hSPI1; /* Inertial Management */
    void MX_SPI_Init(void)
    hSPI1.Instance = SPI1;
    hSPI1.Init.Mode = SPI_MODE_MASTER;
    hSPI1.Init.Direction = SPI_DIRECTION_2LINES;
    hSPI1.Init.DataSize = SPI_DATASIZE_8BIT;
    hSPI1.Init.CLKPolarity = SPI_POLARITY_LOW;
    hSPI1.Init.CLKPhase = SPI_PHASE_1EDGE;
    hSPI1.Init.NSS = SPI_NSS_SOFT;
    hSPI1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_64; /* HSE 8MHz, Full-duplex, 750.0Kbps */
    hSPI1.Init.FirstBit = SPI_FIRSTBIT_MSB;
    hSPI1.Init.TIMode = SPI_TIMODE_DISABLE;
    hSPI1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
    hSPI1.Init.CRCPolynomial = 7;
    hSPI1.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
    hSPI1.Init.NSSPMode = SPI_NSS_PULSE_DISABLE;
    HAL_SPI_Init(&hSPI1);
    2. dummy_byte (https://github.com/BoschSensortec/BMI270-Sensor-API, v2.63.1)
    int8_t bmi270_init(struct bmi2_dev *dev)
    { if (dev->intf == BMI2_SPI_INTF) { dev->dummy_byte = 0;/*1*/ } }
    3. common.c
    #define BMI270_MAX_READ_WRITE_LEN 38
    static SPI_HandleTypeDef *hSPI = &hSPI1;
    static uint8_t spiBuf[BMI270_MAX_READ_WRITE_LEN+1];
    BMI2_INTF_RETURN_TYPE bmi2_spi_read(uint8_t reg_addr, uint8_t *reg_data, uint32_t len, void *intf_ptr)
    uint8_t r;
    if (len == 0 || len > BMI270_MAX_READ_WRITE_LEN)
    return BMI2_E_OUT_OF_RANGE;
    if (reg_data == NULL)
    return BMI2_E_NULL_PTR;
    GpioOutputOff(SPI_CS_BMI270_GPIO_PORT, SPI_CS_BMI270_GPIO_PIN);
    spiBuf[0] = reg_addr;
    r = HAL_SPI_Transmit(hSPI, spiBuf, 1, 1000);
    //while(hSPI->State == HAL_SPI_STATE_BUSY); // wait for xmission complete
    if (r == 0)
    memset(spiBuf, 0x00, sizeof(spiBuf));
    r = HAL_SPI_Receive(hSPI, spiBuf, len+1, 1000);
    memcpy(reg_data, &spiBuf[1], len); /* The first byte is dummy */
    GpioOutputOn(SPI_CS_BMI270_GPIO_PORT, SPI_CS_BMI270_GPIO_PIN);
    return (r == 0) ? BMI2_INTF_RET_SUCCESS : BMI2_E_COM_FAIL;
    BMI2_INTF_RETURN_TYPE bmi2_spi_write(uint8_t reg_addr, const uint8_t *reg_data, uint32_t len, void *intf_ptr)
    uint8_t r;
    memcpy(&spiBuf[1], reg_data, len);
    r = HAL_SPI_Transmit(hSPI, spiBuf, len+1, 1000);
    void bmi2_delay_us(uint32_t period, void *intf_ptr)
    uint32_t msec = period / 1000U;
    if (period % 1000U != 0U)
    msec++;
    vTaskDelay(msec); // I'm using FreeRTOS v202012.00-LTS
    int8_t bmi2_interface_init(struct bmi2_dev *bmi, uint8_t intf)
    memset(bmi, 0, sizeof(struct bmi2_dev));
    bmi->intf = intf;
    bmi->delay_us = bmi2_delay_us;
    bmi->read_write_len = BMI270_MAX_READ_WRITE_LEN;
    bmi->config_file_ptr = NULL; /* Assign to NULL to load the default config file */
    bmi->read = bmi2_spi_read;
    bmi->write = bmi2_spi_write;
    return BMI2_OK;
    4. application
    res = bmi2_interface_init(&bmi2_dev, BMI2_SPI_INTF);
    uint8_t chipId;
    res = bmi2_get_regs(BMI2_CHIP_ID_ADDR, &chipId, 1, &bmi2_dev); // It does not work without this line
    res = bmi270_init(&bmi2_dev);
    5. spi packet
    I'm attaching an excel file. I did not check all 8K data but I think the 8K data is correct. The "load_status" is not valid.
    It worked only 3 times among hundreds trials.
    Would you help me please?
    Hugh
    10 REPLIES 10
    Jet
    Occasional Contributor
    Re: [Question] BMI270 : BMI2_E_CONFIG_LOAD
    Hi Sir:
         Did you get BMI270 chip_id?
         Why did you set dev->dummy_byte = 0? dev->dummy_byte  should be set 1 when choosing SPI communication.
         I always use stm32f411 platform. If necessary, the related reference code can be shared.
    Hugh
    Hi Jet,
    Thanks a lot for your reply.
    Yes, I get the correct chip_id. The previously attached "spi.xlsx" shows that all 8K communication is correct. Only the "load_status" is not valid.
    I moved it in to my "bmi2_spi_read" just for my test.
    Great! I'll get a STM32F411 EVM and start with it. Would you send me the reference code please?
    Best regards,
    Hugh (perceiv2@gmail.com)
    Jet
    Hi Sir:
        Please see the attachment,which is my test code, recommend you to verify them on your platform.
        Any questions, please discuss with me.
    Hugh
    Hi Jet,
    Thank you very much for your reference code.
    Before I get STM32F2 EVM, I've applied it to STM32L4 EVM.
    The initialization was successful once but mostly it reports BMI2_E_CONFIG_LOAD or BMI2_E_DEV_NOT_FOUND.
    I have a stupid question. I'm using a shuttle board labeled "BOSCH BMI260_A2".
    The dealer told me that it is BMI270 shuttle board. Can I continue with that shuttle board?
    Best regards,
    Hugh
