11-07-2022 08:14 AM
I am trying to integrate ESP32-S3 with BME680 using I2C.
Currently I am observing changes in Humidity, Temperatures but IAQ value is not changing. We tring blowing air near the sensor.
Is there a way can i verify BME680 sensor library without sensor.
Please let me know how shall validate the IAQ values i am reading from the sensor.
For reference i have attached screenshot of sensor values read.
12-19-2022 08:17 AM
Hi Arvind,
1. You could refer run-in status description in integration guide.
2. The sensor data will be read according to the new data flag in the 0x1d register.
static int8_t read_field_data(struct bme680_field_data *data, struct bme680_dev *dev)
int8_t rslt;
uint8_t buff[BME680_FIELD_LENGTH] = { 0 };
uint8_t gas_range;
uint32_t adc_temp;
uint32_t adc_pres;
uint16_t adc_hum;
uint16_t adc_gas_res;
uint8_t tries = 10;
/* Check for null pointer in the device structure*/
rslt = null_ptr_check(dev);
do {
if (rslt == BME680_OK) {
rslt = bme680_get_regs(((uint8_t) (BME680_FIELD0_ADDR)), buff, (uint16_t) BME680_FIELD_LENGTH,
dev);
data->status = buff[0] & BME680_NEW_DATA_MSK;
data->gas_index = buff[0] & BME680_GAS_INDEX_MSK;
data->meas_index = buff[1];
/* read the raw data from the sensor */
adc_pres = (uint32_t) (((uint32_t) buff[2] * 4096) | ((uint32_t) buff[3] * 16)
| ((uint32_t) buff[4] / 16));
adc_temp = (uint32_t) (((uint32_t) buff[5] * 4096) | ((uint32_t) buff[6] * 16)
| ((uint32_t) buff[7] / 16));
adc_hum = (uint16_t) (((uint32_t) buff[8] * 256) | (uint32_t) buff[9]);
adc_gas_res = (uint16_t) ((uint32_t) buff[13] * 4 | (((uint32_t) buff[14]) / 64));
gas_range = buff[14] & BME680_GAS_RANGE_MSK;
data->status |= buff[14] & BME680_GASM_VALID_MSK;
data->status |= buff[14] & BME680_HEAT_STAB_MSK;
if (data->status & BME680_NEW_DATA_MSK) {
data->temperature = calc_temperature(adc_temp, dev);
data->pressure = calc_pressure(adc_pres, dev);
data->humidity = calc_humidity(adc_hum, dev);
data->gas_resistance = calc_gas_resistance(adc_gas_res, gas_range, dev);
break;
/* Delay to poll the data */
dev->delay_ms(BME680_POLL_PERIOD_MS);
tries--;
} while (tries);
if (!tries)
rslt = BME680_W_NO_NEW_DATA;
return rslt;
