    Reading data from BMI160
    Alex2hsrw
    Im trying to use BMi160 as an external interrupt with MSP430 in low power mode. So far interrupt feature works perfectly and I can wake up MSP430 from sleep mode by moving BMI160. However I also want to read the accel, after its being moved and show data on console. Which does not work correctly.  I am using a function process() to read z-axis accel and printing the values, but i see wrong values as :
    Output in console when accelerometer is laying on table without any movement:
    Z-axis: -24767.000000
    Z-axis: -28095.000000
    Z-axis: 23617.000000
    Z-axis: -4031.000000
    Z-axis: -31167.000000
    Z-axis: -8895.000000
    Z-axis: 2625.000000
    Z-axis: -19390.000000
    Z-axis: 14401.000000
    Z-axis: 31553.000000
    Z-axis: 9281.000000
    Z-axis: 10305.000000
    Z-axis: -32703.000000
    Output in console when accelerometer is moved:
    Z-axis: 12865.000000
    Z-axis: -185.000000
    Z-axis: -129.000000
    Z-axis: -129.000000
    Z-axis: 127.000000
    Z-axis: -128.000000
    Z-axis: 18559.000000
    Z-axis: 51.000000
    Z-axis: -128.000000
    Z-axis: 127.000000
    Z-axis: -128.000000
    Z-axis: -32385.000000
    Z-axis: -25285.000000
    Z-axis: 10561.000000
    Z-axis: 67.000000
    Here it can be seen that when accelerometer is on rest, i get higher values and when accelerometer is being moved, output comes closer to 127 or 128. Sometimes, I can also see random jump in values in between.
    My Code:
    #include "driverlib.h"
    #include <gpio.h>
    #include <msp430fr5xx_6xxgeneric.h>
    #include <stdint.h>
    #include <stdio.h>
    // Address of the BMI160
    #define SLAVE_ADDR 0x69
    #define MAX_BUFFER_SIZE 20
    #define SAMPLES 1000
    #define ACCEL_SCALE 16384.0 // Scale factor for ±2g range (default)
    int16_t input[SAMPLES] = {0}; // Store samples
    void initI2C() {
        UCB1CTLW0 = UCSWRST;                      // Enable SW reset
        UCB1CTLW0 |= UCMODE_3 | UCMST | UCSSEL__SMCLK | UCSYNC; // I2C master mode, SMCLK
        UCB1BRW = 160;                            // fSCL = SMCLK/160 = ~100kHz
        UCB1I2CSA = SLAVE_ADDR;                   // Slave Address
        UCB1CTLW0 &= ~UCSWRST;                    // Clear SW reset, resume operation
    void I2C_Master_WriteReg(uint8_t dev_addr, uint8_t reg_addr, uint8_t *data, uint8_t count) {
        // Send start condition
        UCB1CTLW0 |= UCTR | UCTXSTT;
        while (!(UCB1IFG & UCTXIFG)); // Wait for TX buffer to be ready
        // Send device address with write flag
        UCB1TXBUF = dev_addr << 1; // Address with write bit
        // Send register address
        UCB1TXBUF = reg_addr;
        // Send data
        for (int i = 0; i < count; i++) {
            UCB1TXBUF = data[i];
        // Send stop condition
        UCB1CTLW0 |= UCTXSTP;
        while (UCB1CTLW0 & UCTXSTP); // Wait for stop condition
    void I2C_Master_ReadReg(uint8_t dev_addr, uint8_t *data, uint8_t count) {
        // Send repeated start and switch to receive mode
        UCB1CTLW0 &= ~UCTR;
        UCB1CTLW0 |= UCTXSTT;
        while (UCB1CTLW0 & UCTXSTT);
        // Receive data
            while (!(UCB1IFG & UCRXIFG0));
            data[i] = UCB1RXBUF;
    void initGPIO() {
        // I2C pins (P4.0 is SDA, P4.1 is SCL)
        P4SEL1 |= BIT0 | BIT1;
        P4SEL0 &= ~(BIT0 | BIT1);
        // Configure INT1 pin (P3.2) as input
        P3DIR &= ~BIT2;
        P3IES &= ~BIT2; // Interrupt on rising edge
        P3IFG &= ~BIT2; // Clear interrupt flag
        P3IE |= BIT2;   // Enable interrupt
        // Configure INT2 pin (P3.3) as input
        P3DIR &= ~BIT3;
        P3IES &= ~BIT3; // Interrupt on rising edge
        P3IFG &= ~BIT3; // Clear interrupt flag
        P3IE |= BIT3;   // Enable interrupt
        PM5CTL0 &= ~LOCKLPM5; // Disable the GPIO power-on default high-impedance mode
    void init_BMI160_ACC() {
        uint8_t writeData[2];
        // Soft reset BMI160
        writeData[0] = 0xB6;
        I2C_Master_WriteReg(SLAVE_ADDR, 0x7E, writeData, 1);
        __delay_cycles(55000); // Delay 55ms for BMI160 to stabilize
        // Set accelerometer to LPM mode
        writeData[0] = 0x12;
        __delay_cycles(5000); // Delay 5ms for accelerometer to stabilize
        // Set ODR to 100Hz with no average
        writeData[0] = 0x86;
        I2C_Master_WriteReg(SLAVE_ADDR, 0x40, writeData, 1);
        // Set both INT1  pin as output, active-high, push-pull
        writeData[0] = 0x0A;
        I2C_Master_WriteReg(SLAVE_ADDR, 0x53, writeData, 1);
        // Temporarily latch the interrupt for 80ms
        writeData[0] = 0x09;
        I2C_Master_WriteReg(SLAVE_ADDR, 0x54, writeData, 1);
        // Route single-tap interrupt to INT1 pin
        writeData[0] = 0x04;
        I2C_Master_WriteReg(SLAVE_ADDR, 0x55, writeData, 1);
        // Configure tap sensing
        writeData[0] = 0x14; // Default values
        I2C_Master_WriteReg(SLAVE_ADDR, 0x60, writeData, 1);
        writeData[0] = 0x00; // Default threshold value
        I2C_Master_WriteReg(SLAVE_ADDR, 0x5F, writeData, 1);
        // Enable single-tap and double-tap interrupt
        writeData[0] = 0x07;
        I2C_Master_WriteReg(SLAVE_ADDR, 0x50, writeData, 1);
    #pragma vector=PORT3_VECTOR
    __interrupt void Port_3(void) {
        if (P3IFG & BIT2) {
            P3IFG &= ~BIT2; // Clear the interrupt flag for INT1
            //printf("Single-tap detected!\n");
            process();
    void process() {
        for (int i = 0; i < SAMPLES; i++) {
            uint8_t reg_data[2] = {0};
            uint8_t reg_addr = 0x16; // Register address for the Z-axis data (low byte)
            // Write register address
            I2C_Master_WriteReg(SLAVE_ADDR, reg_addr, NULL, 0);
            // Read data
            I2C_Master_ReadReg(SLAVE_ADDR, reg_data, 2);
            // Interpret the received data (Z-axis)
            int16_t raw_data = (int16_t)((reg_data[1] << 😎 | reg_data[0]);
            // Convert raw data to G
            float acceleration_g = raw_data ;
            printf("Z-axis: %f\n", acceleration_g);
     int main(void) {
        WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
        initGPIO();
        initI2C();
        init_BMI160_ACC();
        __enable_interrupt(); // Enable global interrupts
        int i = 0;
        while (1) {
            __low_power_mode_3(); // Enter LPM3
        return 0;
    FAE_CA1
    Please check your code below.
            int16_t raw_data = (int16_t)((reg_data[1] <<  | reg_data[0]);
     (1) It should be (reg_data[1] << 8 | reg_data[0])
    (2) BMI160 accel data has the sensitivity of 16384 LSB/g for x/y/z axes at +/-2g full scale range. So when you want to print z axis g values, you need to divide raw data by 16384 as accelration_g = raw data / 16384.0
