    Reading magnetometer BMX055 in I2C
    MinhNhat
    Hi everyone,
    I am working with the BMX055 sensor and using I2C to communicate.
    The data value of the accelerometer and gyroscope is correct but the raw data from the magnetometer is quite weird.
    I tried to change the direction of the BMX055 sensor in few degrees but its output raw value did not change and. However, when I rotated it in 90 degrees or more the output value of the magnetometer is changed a lot.
    Blue: x-axis
    Green: y-axis
    Red: z-axis
    This my code to read the value of the accelerometer, gyroscope, and magnetometer.
    #include<Wire.h>
    // BMX055 加速度センサのI2Cアドレス
    #define Addr_Accl 0x19  // (JP1,JP2,JP3 = Openの時)
    // BMX055 ジャイロセンサのI2Cアドレス
    #define Addr_Gyro 0x69  // (JP1,JP2,JP3 = Openの時)
    // BMX055 磁気センサのI2Cアドレス
    #define Addr_Mag 0x13   // (JP1,JP2,JP3 = Openの時)
    // センサーの値を保存するグローバル関数
    float xAccl = 0.00;
    float yAccl = 0.00;
    float zAccl = 0.00;
    float xGyro = 0.00;
    float yGyro = 0.00;
    float zGyro = 0.00;
    int   xMag  = 0;
    int   yMag  = 0;
    int   zMag  = 0;
    void setup()
      // Wire(Arduino-I2C)の初期化
      Wire.begin();
      // デバック用シリアル通信は9600bps
      Serial.begin(9600);
      //BMX055 初期化
      BMX055_Init();
      delay(100);
    void loop()
      Serial.println("--------------------------------------");
      //BMX055 加速度の読み取り
      BMX055_Accl();
      //Serial.print("Accl= ");
      Serial.println(xAccl);
      //Serial.print(",");
      Serial.println(yAccl);
      Serial.println(zAccl);
      //Serial.println("");
      //BMX055 ジャイロの読み取り
      BMX055_Gyro();
      //Serial.print("Gyro= ");
      Serial.println(xGyro);
      Serial.println(yGyro);
      Serial.println(zGyro);
      //BMX055 磁気の読み取り
      BMX055_Mag();
      //Serial.print("Mag= ");
      Serial.println(xMag);
      Serial.println(yMag);
      Serial.println(zMag);
      delay(10);
    void BMX055_Init()
      Wire.beginTransmission(Addr_Accl);
      Wire.write(0x0F); // Select PMU_Range register
      Wire.write(0x03);   // Range = +/- 2g
      Wire.endTransmission();
      delay(100);
      Wire.write(0x10);  // Select PMU_BW register
      Wire.write(0x08);  // Bandwidth = 7.81 Hz
      delay(100);
      Wire.write(0x11);  // Select PMU_LPW register
      Wire.write(0x00);  // Normal mode, Sleep duration = 0.5ms
      delay(100);
      Wire.beginTransmission(Addr_Gyro);
      Wire.write(0x0F);  // Select Range register
      Wire.write(0x04);  // Full scale = +/- 125 degree/s
      delay(100);
      Wire.write(0x10);  // Select Bandwidth register
      Wire.write(0x07);  // ODR = 100 Hz
      delay(100);
      Wire.write(0x11);  // Select LPM1 register
      Wire.write(0x00);  // Normal mode, Sleep duration = 2ms
      delay(100);
    //// Addr_Mag 0x13
      Wire.beginTransmission(Addr_Mag);
      Wire.write(0x4B);  // Select Mag register
      Wire.write(0x83);  // Soft reset
      delay(100);
      Wire.write(0x01);  // Soft reset
      delay(100);
      Wire.write(0x4C);  // Select Mag register
      Wire.write(0x00);  // Normal Mode, ODR = 10 Hz
      Wire.write(0x4E);  // Select Mag register
      Wire.write(0x84);  // X, Y, Z-Axis enabled
      Wire.write(0x51);  // Select Mag register
      Wire.write(0x04);  // No. of Repetitions for X-Y Axis = 9
      Wire.write(0x52);  // Select Mag register
      Wire.write(0x16);  // No. of Repetitions for Z-Axis = 15
    void BMX055_Accl()
      int data[6];
      for (int i = 0; i < 6; i++)
        Wire.write((2 + i));// Select data register
        Wire.requestFrom(Addr_Accl, 1);// Request 1 byte of data
        // Read 6 bytes of data
        // xAccl lsb, xAccl msb, yAccl lsb, yAccl msb, zAccl lsb, zAccl msb
        if (Wire.available() == 1)
          data[i] = Wire.read();
      // Convert the data to 12-bits
      xAccl = ((data[1] * 256) + (data[0] & 0xF0)) / 16;
      Serial.println("here");
      if (xAccl > 2047)  xAccl -= 4096;
      yAccl = ((data[3] * 256) + (data[2] & 0xF0)) / 16;
      if (yAccl > 2047)  yAccl -= 4096;
      zAccl = ((data[5] * 256) + (data[4] & 0xF0)) / 16;
      if (zAccl > 2047)  zAccl -= 4096;
      xAccl = xAccl * 0.0098; // renge +-2g
      yAccl = yAccl * 0.0098; // renge +-2g
      zAccl = zAccl * 0.0098; // renge +-2g
    void BMX055_Gyro()
      int data[6];
        Wire.write((2 + i));    // Select data register
        Wire.requestFrom(Addr_Gyro, 1);    // Request 1 byte of data
        // xGyro lsb, xGyro msb, yGyro lsb, yGyro msb, zGyro lsb, zGyro msb
      // Convert the data
      xGyro = (data[1] * 256) + data[0];
      if (xGyro > 32767)  xGyro -= 65536;
      yGyro = (data[3] * 256) + data[2];
      if (yGyro > 32767)  yGyro -= 65536;
      zGyro = (data[5] * 256) + data[4];
      if (zGyro > 32767)  zGyro -= 65536;
      xGyro = xGyro * 0.0038; //  Full scale = +/- 125 degree/s
      yGyro = yGyro * 0.0038; //  Full scale = +/- 125 degree/s
      zGyro = zGyro * 0.0038; //  Full scale = +/- 125 degree/s
    void BMX055_Mag()
      int data[8];
      for (int i = 0; i < 8; i++)
        Wire.write((0x42 + i));    // Select data register
        Wire.requestFrom(Addr_Mag, 1);    // Request 1 byte of data
        // xMag lsb, xMag msb, yMag lsb, yMag msb, zMag lsb, zMag msb
      // Convert the data
      xMag = ((data[1] <<8) | (data[0]>>3));
      if (xMag > 4095)  xMag -= 8192;
      yMag = ((data[3] <<8) | (data[2]>>3));
      if (yMag > 4095)  yMag -= 8192;
      zMag = ((data[5] <<8) | (data[4]>>3));
      if (zMag > 16383)  zMag -= 32768;
    My question is:
    1> Is this the correct way(correct registers) to read the magnetometer data?
    2> If my code is correct, what happens to my magnetometer raw data?
    Thank you
    Jet
    Occasional Contributor
    Re: Reading magnetometer BMX055 in I2C
    Hi Sir:
         Recommend you to read the offecial BMM150 api code to know how to get the magetometer data.  I don't see you to use trim values after you read the mag data registers.
         Please see the following link:
         https://www.bosch-sensortec.com/products/motion-sensors/absolute-orientation-sensors/absolute-orient...
         Hopefully, it can help you.
