I would like to readout multiple BME688 simultaniously. I created two instances of Bsec2, and afterwards i do each step for both instances. I kept the NewDataCallback the same, as one input parameter is the BSEC instance. In BSEC2 i get an error 100 from BSEC2.
Please let me know what is the problem .
Bsec2 envSensors[2];
for(int i = 0; i < NUMBEROFDEVICES; i ++)
//Set multiplexer
if (!envSensors[i].begin(BME68X_I2C_ADDR_LOW, Wire))
checkBsecStatus(envSensors[i]);
/* Subsribe to the desired BSEC2 outputs */
if (!envSensors[i].updateSubscription(sensorList, ARRAY_LEN(sensorList), BSEC_SAMPLE_RATE_LP))
/* Whenever new data is available call the newDataCallback function */
envSensors[i].attachCallback(newDataCallback);
envSensors[i].index = i;
Serial.println("BSEC library version " + \
String(envSensors[i].version.major) + "." \
+ String(envSensors[i].version.minor) + "." \
+ String(envSensors[i].version.major_bugfix) + "." \
+ String(envSensors[i].version.minor_bugfix));
I checked the Arduino example for x8 board, which has 8 times BME688 and Multiplexer. It seems like the example is reading and processing only 1 BME688 sensor.
Kind Regards
Hello hugehead,
You could refer this example code on github: https://github.com/BoschSensortec/BSEC-Arduino-library/blob/master/examples/basic_config_state_multi...
Hello Robin,
the example is from BSEC(v1), i am using BSEC V2 right now. Which - iguess - is the most recent, right? I am running on MKRZero right now, using the basic example without writing to the EEPROM. It seems that the example above is for BME680, not for BME688.
I have attached 2x BME688 Pi3g dev board (ADDR HIGH, ADDR LOW), this example works different and has the newDataCallback. can assume from the output that sometimes it reads sensor 1 and sometimes sensor 2 (because of different "Gas resistance") but the values are coming irregularly. I assume it should come every ~3 seconds.
Additionally, i get warning 100, which is relate to timing from your precompiled library? Output is below and attached my example code.
14:16:51.072 -> BSEC library version 2.0.6.1
14:16:51.141 -> BSEC warning code : 100
14:16:54.102 -> BSEC outputs:
14:16:54.102 -> timestamp = 3875
14:16:54.102 -> iaq = 25.00
14:16:54.102 -> iaq accuracy = 0
14:16:54.102 -> temperature = 22.49
14:16:54.102 -> pressure = 99600.37
14:16:54.102 -> humidity = 42.72
14:16:54.102 -> gas resistance = 5684.85
14:16:54.102 -> stabilization status = 1.00
14:16:54.102 -> run in status = 0.00
14:16:54.102 -> BSEC warning code : 100
14:16:57.072 -> BSEC outputs:
14:16:57.072 -> timestamp = 6875
14:16:57.072 -> iaq = 25.00
14:16:57.072 -> iaq accuracy = 0
14:16:57.072 -> temperature = 22.60
14:16:57.072 -> pressure = 99604.23
14:16:57.106 -> humidity = 42.71
14:16:57.106 -> gas resistance = 5684.85
14:16:57.106 -> stabilization status = 1.00
14:16:57.106 -> run in status = 0.00
14:16:57.106 -> BSEC warning code : 100
14:17:00.069 -> BSEC outputs:
14:17:00.069 -> timestamp = 9875
14:17:00.104 -> iaq = 25.00
14:17:00.104 -> iaq accuracy = 0
14:17:00.104 -> temperature = 22.70
14:17:00.104 -> pressure = 99610.11
14:17:00.104 -> humidity = 42.56
14:17:00.104 -> gas resistance = 5684.85
14:17:00.104 -> stabilization status = 1.00
14:17:00.104 -> run in status = 0.00
14:17:00.104 -> BSEC warning code : 100
14:17:03.156 -> BSEC warning code : 100
14:17:06.099 -> BSEC outputs:
14:17:06.099 -> timestamp = 15875
14:17:06.099 -> iaq = 25.00
14:17:06.099 -> iaq accuracy = 0
14:17:06.099 -> temperature = 25.06
14:17:06.099 -> pressure = 99588.34
14:17:06.099 -> humidity = 38.31
14:17:06.099 -> gas resistance = 87581.25
14:17:06.099 -> stabilization status = 1.00
14:17:06.099 -> run in status = 0.00
14:17:06.099 -> BSEC warning code : 100
14:17:09.089 -> BSEC outputs:
14:17:09.089 -> timestamp = 18875
14:17:09.089 -> iaq = 25.00
14:17:09.089 -> iaq accuracy = 0
14:17:09.089 -> temperature = 25.12
14:17:09.089 -> pressure = 99589.26
14:17:09.089 -> humidity = 38.24
14:17:09.089 -> gas resistance = 97061.61
14:17:09.089 -> stabilization status = 1.00
14:17:09.089 -> run in status = 0.00
14:17:09.089 -> BSEC warning code : 100
14:17:12.086 -> BSEC outputs:
14:17:12.086 -> timestamp = 21875
14:17:12.086 -> iaq = 25.00
14:17:12.086 -> iaq accuracy = 0
14:17:12.086 -> temperature = 25.19
14:17:12.086 -> pressure = 99587.47
14:17:12.086 -> humidity = 38.11
14:17:12.086 -> gas resistance = 102359.05
14:17:12.086 -> stabilization status = 1.00
14:17:12.086 -> run in status = 0.00
14:17:12.086 -> BSEC warning code : 100
14:17:15.081 -> BSEC outputs:
14:17:15.081 -> timestamp = 24875
14:17:15.081 -> iaq = 25.00
14:17:15.081 -> iaq accuracy = 0
14:17:15.081 -> temperature = 22.74
14:17:15.081 -> pressure = 99607.55
14:17:15.081 -> humidity = 42.38
14:17:15.081 -> gas resistance = 5974.61
14:17:15.081 -> stabilization status = 1.00
14:17:15.081 -> run in status = 0.00
14:17:15.081 -> BSEC warning code : 100
14:17:18.083 -> BSEC outputs:
14:17:18.083 -> timestamp = 27875
14:17:18.083 -> iaq = 25.00
14:17:18.083 -> iaq accuracy = 0
14:17:18.083 -> temperature = 22.61
14:17:18.083 -> pressure = 99604.16
14:17:18.083 -> humidity = 42.30
14:17:18.083 -> gas resistance = 6412.83
14:17:18.083 -> stabilization status = 1.00
14:17:18.083 -> run in status = 0.00
14:17:18.083 -> BSEC warning code : 100
Really apperciate your help.
Kind Regards
Matthias
Hello hugehead,
For BSE2, you could refer BSEC2 code on github that supported multiple BME68X sensors.
https://github.com/BoschSensortec/Bosch-BSEC2-Library
Multiple sensors example code: https://github.com/BoschSensortec/Bosch-BSEC2-Library/tree/master/examples/x8_board_examples
Hello Robin,
as described above, i checked that example already. My assumption has been, as yours, that it will read multiple BME688 sensors. But in fact, I can read one BME688 from the x8 board.
As you can see, it is creating ONE object of BME688, not multiple.
/* Create an object of the class Bsec2 */
Bsec2 envSensor;
commMux commConfig;
and is reading one sensor at a time. I would like to accomplish a scenario, where i can read multiple sensors at a time like in my attached arduino example above. Then, i get some error 100. Please help me to find a solution to read multiple BME688 at a time.
