04-22-2023 03:55 AM
Does anyone have any pointers to the Bosch/Sensortec 6 and 9 axis IMU patents or release dates? I found a Bosch chart showing the first 3-axis and 6 axis IMU happened in 2012. But I need to find something more official. Ideally the patent, or release announcement.
04-24-2023 03:10 AM - edited 04-24-2023 03:10 AM
Hi shorton,
Could we know what is the purpose for which you are looking for patent, or release announcement?
04-24-2023 04:03 AM - edited 04-24-2023 04:08 AM
Hey Robin, thanks for the reply. I'm just doing a basic research paper on when lean angles sensors started becoming available for motorcycle ABS system use. I tried hard to find myself and I found some bits that are probably related but not very specific. I'd love information on both axis count sensors if possible. I have soem Bosch docs that show the timelines for MEMS use but was trying to pin down when the lean sensors IMUs became avaialble for use. I figured when the patents were done might be a good marker for that. But releases would be good too. Thanks very much for any assistance or pointers you could help with.
06-14-2023 08:02 AM
Hi shorton,
As your application is motorcycle ABS system with safety related, but Bosch Sensortec's products are consumer grade sensors. I'm not sure if this will matche your application. If you have a specific sensor part number, I can check it internally.
