    SPI problem with BMI160
    SaberKazemi1992
    I am trying to have SPI connectio as interface protocol between BMI160 shuttle board/MSP432P401R. What I need is the accel/gyroscope data continuously.  The main functions I am using is from BMI160 drivers found on github:
    https://github.com/BoschSensortec/BMI160_driver
    I have defined the user_spi_read/user_spi_write as below:
    int8_t user_spi_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    SPI_BMI160_BEGIN;
    /* send register address byte */
    SPI_BMI160_TX(reg_addr);
    /* Storing chip status */
    // SPI_BMI160_RX(rslt);
    for (i = 0; i < len; i++)
    SPI_BMI160_TX(*reg_data);
    reg_data++;
    return (rslt);
    And
    int8_t user_spi_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    int i;
    /* Pull CS_N low*/
    SPI_BMI160_BEGIN;
    //SPI_BMI160_RX(rslt);/////////////////?????
    /* Communicate len number of bytes: if RX - the procedure sends 0x00 to push bytes from slave*/
    SPI_BMI160_TX(0); /* Possible to combining read and write as one access type */
    // SPI_WAIT_DONE();
    SPI_BMI160_RX(*reg_data); /* Store pData from last pData RX */
    reg_data++;
    /* Pull CS_N low*/
    SPI_BMI160_END;
    /* return the status byte value */
    return(rslt);
    The functions for SPI (in MSP432p401R) abbreviated as below:
    #define SPI_BMI160_BEGIN              P6OUT &= ~BIT2;
    #define SPI_BMI160_TX(x)                do{while(!(UCTXIFG & UCB1IFG));UCB1TXBUF= (x);}while(1==-1)
    #define SPI_BMI160_RX(x)                do{while(!(UCRXIFG & UCB1IFG));(x)=UCB1RXBUF;}while(1==-1)
    #define SPI_BMI160_END                   P6OUT |= BIT2;
    Is this correct form for SPI wirte/read functions? Seems SPI is not working.
    Saber
    shellywang
    Occasional Contributor
    It is recommended to observe the waveform using a logic analyzer or oscilloscope.
    Here are some suggestions in terms of the code:
    1. After power-on reset, the BMI160 is in I2C state by default. Therefore, a dummy read of register 0x00 is required to switch to SPI bus.
    2. For write operations, reg_address should be ANDed with 0x7f and then sent out. For example, to write the address 0x40, 0x40 is ANDed with 0x7f, i.e.  0x40 & 0x7f, and the result 0x40 is sent out.
    3. For read operations, reg_address should be ORed with 0x80 and then sent out. For example, to read the address 0x40, 0x40 is ORed with 0x80, i.e. 0x40 | 0x80, and the result 0xC0 is sent out.
    Thanks for your previous reply.
    On 2 and 3, you mentioned that for read/write operations, the registers need to be ORed/ANDed with 0x7F/0x40 respectively. Does it apply to I2C as well?
    Saber
    No. Only for SPI.
    Background: In i2c the R/W bit is part of the address byte. In SPI, there is no address byte and the R/W bit is part of the command byte.
    o_o
    Hello
    Thanks for your previous answer. Maybe a trivial question 🙂:
    In #1, you mentioned to switch to SPI, a dummy read of 0x00 should be done. Can you please explain how I can do it?
    The SPI write and read instances are like below:
    int8_t user_spi_write(int8_t dev_id, int8_t reg_addr, int8_t *reg_data, int8_tlength)
    int8_t rslt = BMI160_OK; /* Return 0 for Success, non-zero for failure */
    SPI_BMI160_BEGIN;
    SPI_BMI160_TX(reg_addr & 0x7F);
    __delay_cycles(200);
    for (i = 0; i < length; i++)
    reg_data++;
    SPI_BMI160_END;
    return rslt;
    int8_t user_spi_read(int8_t dev_id, int8_t reg_addr, int8_t *reg_data, int8_tlength)
    SPI_BMI160_BEGIN;
    SPI_BMI160_TX(reg_addr | 0x80);
    SPI_BMI160_TX(0);
    reg_data++;
    SPI_BMI160_END;
    return rslt;
    Saber
