    SPI problem with BMI160
    SaberKazemi1992
    I am trying to have SPI connectio as interface protocol between BMI160 shuttle board/MSP432P401R. What I need is the accel/gyroscope data continuously.  The main functions I am using is from BMI160 drivers found on github:
    I have defined the user_spi_read/user_spi_write as below:
    int8_t user_spi_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    int8_t rslt = 0; /* Return 0 for Success, non-zero for failure */
    SPI_BMI160_BEGIN;
    /* send register address byte */
    SPI_BMI160_TX(reg_addr);
    /* Storing chip status */
    // SPI_BMI160_RX(rslt);
    for (i = 0; i < len; i++)
    SPI_BMI160_TX(*reg_data);
    reg_data++;
    return (rslt);
    And
    int8_t user_spi_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    int i;
    /* Pull CS_N low*/
    SPI_BMI160_BEGIN;
    //SPI_BMI160_RX(rslt);/////////////////?????
    /* Communicate len number of bytes: if RX - the procedure sends 0x00 to push bytes from slave*/
    SPI_BMI160_TX(0); /* Possible to combining read and write as one access type */
    // SPI_WAIT_DONE();
    SPI_BMI160_RX(*reg_data); /* Store pData from last pData RX */
    reg_data++;
    /* Pull CS_N low*/
    SPI_BMI160_END;
    /* return the status byte value */
    return(rslt);
    The functions for SPI (in MSP432p401R) abbreviated as below:
    #define SPI_BMI160_BEGIN              P6OUT &= ~BIT2;
    #define SPI_BMI160_TX(x)                do{while(!(UCTXIFG & UCB1IFG));UCB1TXBUF= (x);}while(1==-1)
    #define SPI_BMI160_RX(x)                do{while(!(UCRXIFG & UCB1IFG));(x)=UCB1RXBUF;}while(1==-1)
    #define SPI_BMI160_END                   P6OUT |= BIT2;
    Is this correct form for SPI wirte/read functions? Seems SPI is not working.
    Saber
    In your case, do something like this:
    int8_t dummy;
    user_spi_read(0, 0, &dummy, 1);
    o_o
