10-06-2023 11:19 AM - edited 10-06-2023 11:20 AM
Could someone help me modify my existing code to include the Spectral Density parameter and complete the gyroscope simulation? Here's the code snippet I've been working with:
https://gist.github.com/michaelwro/126de51e3d2bcaeda3fb5609aa19f0e5[sudo code link]1
# Pseudocode for modeling a noisy gyro sensor
# Created By: MicWro Engr
# 'w' variables are supposed to be the Greek letter omega, used to denote the angular rate
# Remember: variance = (std_dev)^2
# Gyro model:
# w_meas = w_true + bias + noise
# I obtained these values from my own gyro sensor! Details can be found at: https://mwrona.com/posts/gyro-noise-analysis/
# This Mathworks post is really useful: https://www.mathworks.com/help/fusion/ug/inertial-sensor-noise-analysis-using-allan-variance.html
import numpy as np
dt = 0.01 # [sec] sample rate
# Gyro bias parameters
w_bias = -0.01 # This is the constant offset in rate measurements. Also acts as the integrator's initial condition
bias_coef = 1.31e-4 # Bias instability coefficient
bias_var = ((2 * bias_coef**2) / np.pi) * np.log(2) # bias instability variance
# Angle random walk (AWR) parameters
arw_coef = 4.54e-4 # ARW coefficient
arw_var = arw_coef**2 / dt # [rad/sqrt(sec)] ARW variance
# simulation loop
while True:
# obtain an actual rate from ground truth simulation
w_actual = GroundTruth(...)
# simulate bias instability noise
w_bias += dt * np.random.normal(0, np.sqrt(bias_var)) # (mean, std_dev)
# simulate angle random walk noise
w_arw = np.random.normal(0, np.sqrt(arw_var))
# simulated gyro measurement
w_meas = w_actual + w_bias + w_arw
Any guidance, code examples, or explanations would be greatly appreciated. Thank you for your assistance!
10-06-2023 05:56 PM
Hi jimit007,
We have not conducted any analysis of third-party code. You can consult the third-party author for more information on code implementation.
