    Sinusoidal Noise observed in BMG250 Gyroscope
    Sandy
    I am using BMG250 MEMS gyroscope. I am observing a "Sinusoidal Noise" of primary frequency approximately 8 Hz in a few samples of the sensors. I have attached the plots for the reference. I am not able to decode the reason behind the same. This is also reflecting in the Allan plot and seriously affecting the ARW values. I request you to please suggest any solution for the same.
    Data points were recorded at the non-vibrating platform with variable sampling rates (50 Hz, 400 Hz). Used different power sources (Dedicated Power Supply, Adaptor, independent battery).
    6 REPLIES 6
    shellywang
    Occasional Contributor
    Hi Sandy,
    Coluld you give more information below?
    • raw data log of BMG250, X/Y/Z axis
    • configuration: like range, operation mode, power mode , bandwidth
    • it's better add accelerometer in the testing and log the acc data at the same time.
    • what's kind of rotation table  used ?
    - Accelerometer and Gyro data is attached here.
    - configuration: Range-500 deg/sec, ODR: 400 Hz, Mode: Normal Mode
    - Data was recorded in static conditions on the computer desk and with no surrounding vibrations
    shellywang
    Could you upload the Acc and Gyro data log?
    Accelerometer and gyroscope data is attached.
