Hello
I am interested in using the BMM150 Geomagnetic Sensor in a product but I would need to know where the hall sensors are located within the package* and what the geometrical extent of the hall plates are.
Thank you very much
*(see Figure 20 on Page 45 in the datasheet of the BMM150 which is provided by the supplier Digikey: https://www.digikey.com/product-detail/en/bosch-sensortec/BMM150/828-1044-1-ND/4196683)
With BMM150, the X&Y axis are using a proprietary flip-core sensing technology. The Z axis is indeed hall effect. Although the exact location is not disclosed, they are clearly visible under a microscope when viewed from the bottom.
BMM150 bottom view
