06-19-2020 09:02 AM - edited 06-19-2020 09:04 AM
Specific values are different for each bme680 sensor
In some sensors, a temperature value of 3350 is often measured.
The actual temperature value is about 2832,
Actual temperature value and specific value are measured almost alternately
The actual temperature value changes depending on the temperature
But that particular value, measured almost alternately, does not change.
Why are these useless values constantly measured?
06-25-2020 04:37 PM
BME680 temperature sensor has typical +/-1C accuracy compared to the actual ambient temperature. If BME680 is placed near heat source in your system, then the temperature measurements will be higher than the actual ambient temperature. Please refer to BME680 handling, soldering and mounting instructions at https://www.bosch-sensortec.com/media/boschsensortec/downloads/handling_soldering_mounting_instructi... for more information.
