12-01-2021 06:20 AM
Hello Community,
I am working on the BME688 sensor with the Raspberry pi.
I am referring to the BME68X Sensor API to port the application to raspberry pi CM4.
I am not using the COINES Tool to communicate with the sensor device. Instead of that, I am using the I2C interface.
Till now I am able to port the application & run the Force mode example successfully.
& getting the following result as output.
Note: I haven't printed the TimeStamp value here.
I2C Interface
Sample, TimeStamp(ms), Temperature(deg C), Pressure(Pa), Humidity(%), Gas resistance(ohm), Status
1, 00000000, 31.53, 94684.11, 44.89, 219459.92, 0xa0
2, 00000000, 31.71, 94687.38, 44.91, 7887.60, 0xb0
3, 00000000, 32.17, 94678.07, 44.96, 9411.76, 0xb0
4, 00000000, 32.58, 94677.10, 44.99, 12741.39, 0xb0
5, 00000000, 32.85, 94684.97, 45.00, 16060.23, 0xb0
6, 00000000, 33.04, 94675.18, 44.99, 19282.92, 0xb0
7, 00000000, 33.17, 94677.45, 44.97, 22260.87, 0xb0
8, 00000000, 33.29, 94680.03, 44.93, 25559.11, 0xb0
9, 00000000, 33.37, 94682.83, 44.87, 28064.02, 0xb0
Now,
I would like to know,
1. Is this data is valid or not?
2. What does status code 0xa0 & 0xb0 actually mean?
Will you please help me to understand this?
Regards,
Shiv Patil.
03-12-2024 05:16 PM
3 status bits to check when measuring data
1. new_data, the mask for this bit is 1000000 (0x80)
2. gas_valid, the mask for this bit is 00100000 (0x20)
3. heat_stab, the mask for this bit is 00010000 (0x10).
A status of 0xA0 means new_data=1, gas_valid=1, heat_stab=0. Error on heat_stab bit
A status of 0xB0 means new_data=1, gas_valid=1, heat_stab=1. This means the data measurment is valid to use.
03-24-2024 02:39 PM
Did you ever get a response to this question?
