    Technical information on BMP388
    Highlighted
    Hello Team,
    Just joined this forum. I am interested to know minimum change of pressure that can be reliably measured by BMP388 sensor.
    Regards
    Vidyesh
    Highlighted
    Re: Technical information on BMP388
    Hi Vidyesh,
    The answer depends on many factors that you forgot to mention here:
    -Expected rate of change?
    -Method for compensating for weather effects
    -Desired current consumption, data rate
    -Define "reliably". What is your target accuracy?
    The answer probably falls in the 10cm to 100cm range, depending on the use-case.
    o_o
