    The output of BMP280 sensor are too consistent
    Iuliean
    I've used this https://github.com/BoschSensortec/BMP280_driver/tree/master/examples and implemented the i2c functions like this
    int8_t i2c_reg_write(uint8_t i2c_addr, uint8_t reg_addr, uint8_t *reg_data, uint16_t length)
        int fd;
        std::cout << "write";
        fd = open("/dev/i2c-1", O_RDWR);
        std::cout << "fd " << fd;
        if((ioctl(fd, I2C_SLAVE, i2c_addr)) < 0)
            std::cout << "kek1";
        int rres = write(fd, reg_data, length);
        if(rres != length)
            std::cout << " failed to write\n";
        close(fd);
        return 0;
    int8_t i2c_reg_read(uint8_t i2c_addr, uint8_t reg_addr, uint8_t *reg_data, uint16_t length)
        int fd;
        //std::cout << "read";
        fd = open("/dev/i2c-1", I2C_RDWR);
        //std::cout << "fd " << fd;
        int rres = ioctl(fd, I2C_SLAVE, i2c_addr);
        if(rres < 0)
            std::cout << "rkek1 "<< rres << ' ';
        std::cout << "trying to read " << length << "bytes\n";
        for(int i = 0; i < length ; i++)
            __s32 status = i2c_smbus_read_byte_data(fd, reg_addr);
            if( status < 0)
                std::cout << "failed " << status << '\n';
            reg_data[i] = status;
        close(fd);
        /* Implement the I2C read routine according to the target machine. */
        return 0;
    And after i compile temperatures.c and run the program i alway gen the same values 444102, 4671, 46.711974 and i have no i dea why
    I compiled my program on a raspberry pi zero w with this command "g++ temperatures.c bmp280.c -li2c"
    FAE_CA1
    Re: The output of BMP280 sensor are too consistent
    Please refer to the ticket at https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BMP-280-Weird-temperatur-data-with-I2C/m... for more informaiton.
