    To Bosch Github Admins: Please change tagging of the repository
    For the Bosch BSEC Arduino repository  currently tags in format "ard_bsec_v1.5.1474" are used, while "version" field in manifest file library.properties is using format "v1.5.1474".This format mismatch causes the library crawler of platformio.io to reject the library.
    To solve this, please change tagging of releases in github repository to format "v1.5.174" (cut off "ard_bsec_" substring).
    Re: To Bosch Github Admins: Please change tagging of the repository
    Hi cyberman54,
    would it be possible to have both the tags simultaneously, or should there be only 1 tag that matches with the libraries.properties file?
    I am not sure.
    Just try it for latest version, then 48h laters look if the library is shown in platformio registry.
    If not, ask in platformio community forum.
