I followed the instructions in section 5 of the BHI260AB SDK Quick Start Guide in order to use the VirtBSXLeanDeviceOrientation and VirtBSXCustomAccelDataSource custom virtual drivers, and I got the following errors:
Spoiler (Highlight to read) FAILED: user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6 user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.lib.inc cmd.exe /C "cmd.exe /C "cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -E remove C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.usage.csv && cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -P C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/cmake/force_include.cmake 1 C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.lib.inc C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.data/libs C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.data/sections && cd C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build" && C:\arc_gnu\bin\arc-elf32-gcc.exe -mno-sdata -Os -include "C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/common/includes/hw_versions.h" -Werror -Wno-error=deprecated-declarations -g -DROM_NAME=bosch_rom -DROM_VERSION=ROM_7189_DI02 -DUSE_RTOS=1 -DRAM_BANKS_OPTIONAL_MAX=7 -DUSE_FLASH_BOOTLOADER=0 -DENCRYPT_USER_PAYLOAD=0 -DMAX_FLASH_FW_SIZE_SECTORS=2046 -DBHI260_OTP_SENSOR_CALIBRATION -DBHI260_ACCEL_RANGE_OFFSET -DBHI260_GYRO_SENSITIVITY_CORRECTION -DBHI260_GYRO_TIMOSC_PLL -nostartfiles -fno-stack-check -mlong-calls -DBHY2_KLIO_PAGE=9 -D__T7189__ -DDEVICE=0x7189 @"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/common/7189/gcc.arg" -DVERSION=6 -DVERSION_BUGFIX=6 -DVERSION_MAJOR=3 -DVERSION_MINOR=0 -DBUILD_DATE="" -DBUILD_TIME="" -DI2C_QUEUE_SIZE=40 -DCONFIG_HAS_FLOAT_MATRIX=0 -DCONFIG_HAS_BOSCH_EXT_DATA=1 -DLARGE_DECIMATION -DPLACEHOLDER_SENSOR_API -DVIRTUAL_MODE_CHANGE -UVIRTUAL_CURRENT_CONSUMPTION -DVIRTUAL_EXPANSION_DATA -DHAS_ACTUAL_RATE -DINTF_STREAMING -e_start -Wl,--start-group -lm -Wl,--end-group -u gEM7189Config -Wl,-T"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/kernel/kernel-linker.cmd" -u gFwHeader -u gUserEntries -u header_copy_offset -Bdefine:_BUILD_YEAR=2021 -Bdefine:_BUILD_MONTH=4 -Bdefine:_BUILD_DAY=16 -Bdefine:_BUILD_HOUR=13 -Bdefine:_BUILD_MINUTE=26 -Bdefine:_BUILD_SECOND=27 -Bdefine:USER_VERSION=6 -ffunction-sections -fdata-sections -u gFwHeader_copy -Wl,-e -Wl,user_init @"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.lib.inc" @CMakeFiles\user-ram-1ae8a3fe9ff124f08042e312aa3078a6.rsp -o user\user-ram-1ae8a3fe9ff124f08042e312aa3078a6 -Wl,--start-group -Xlinker -Map=user\user-ram-1ae8a3fe9ff124f08042e312aa3078a6.map -Wl,--end-group && cmd.exe /C "cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\bin\initdat -q user-ram-1ae8a3fe9ff124f08042e312aa3078a6 user-ram-1ae8a3fe9ff124f08042e312aa3078a6 !data !lit !bss ~.ram_keys ~.fw_header ~.fw_header_offset ~.em7189_descriptor .phys_sensor_descriptors .virt_sensor_descriptors .timer_sensor_descriptors ~.reclaim ~.vectors ~.fw_header_copy && cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -P C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/cmake/allocations.cmake C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.usage.csv C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.data/libs"" c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: ../libs/MetawarePrintf/libMetawarePrintf.a(_doecvtd.c.obj): in function `_doecvtd': _doecvtd.c:(.text._doecvtd+0x7a): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x7a): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x90): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x90): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xce): undefined reference to `_mwdrdiv_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xce): undefined reference to `_mwdrdiv_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xf4): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xf4): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x11e): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x11e): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x132): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x132): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x140): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x140): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x15a): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x15a): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x16e): undefined reference to `_mwddiv_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x16e): undefined reference to `_mwddiv_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x180): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x180): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x196): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x196): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x1fc): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x1fc): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x204): undefined reference to `_mwdtruncu_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x204): undefined reference to `_mwdtruncu_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x20a): undefined reference to `_mwdfltu_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x20a): undefined reference to `_mwdfltu_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x212): undefined reference to `_mwdrsub_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x212): undefined reference to `_mwdrsub_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: ../libs/MetawarePrintf/libMetawarePrintf.a(_pow10d.c.obj): in function `_pow10d': _pow10d.c:(.text._pow10d+0x22): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _pow10d.c:(.text._pow10d+0x22): undefined reference to `_mwdmul_' collect2.exe: error: ld returned 1 exit status [211/246] Linking C executable user\user-flash-c3900fa0ad1864fd0adb9da62d9ca1b0 [212/246] Linking C executable user\user-flash-d66927bc6b7229a80953ef99e811472a [213/246] Linking C executable user\user-ram-d66927bc6b7229a80953ef99e811472a [214/246] Linking C executable user\user-ram-97df84ec8122a0de8d6cf3413a289112 [215/246] Linking C executable user\user-flash-418c4b99eb6f671a9001c6c1d2106937 [216/246] Linking C executable user\user-flash-97df84ec8122a0de8d6cf3413a289112 [217/246] Linking C executable user\user-flash-b493b6d7e3aa1f3db1c2d38f9a7e6e59 [218/246] Linking C executable user\user-ram-b493b6d7e3aa1f3db1c2d38f9a7e6e59 [219/246] Linking C executable user\user-flash-a9d622d876c13cb67a65e15c2cf77d14 [220/246] Linking C executable user\user-ram-86bdf125440f2c720d9795b58dc7306f [221/246] Linking C executable user\user-flash-1ae8a3fe9ff124f08042e312aa3078a6 FAILED: user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6 user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.lib.inc cmd.exe /C "cmd.exe /C "cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -E remove C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.usage.csv && cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -P C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/cmake/force_include.cmake 1 C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.lib.inc C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.data/libs C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.data/sections && cd C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build" && C:\arc_gnu\bin\arc-elf32-gcc.exe -mno-sdata -Os -include "C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/common/includes/hw_versions.h" -Werror -Wno-error=deprecated-declarations -g -DROM_NAME=bosch_rom -DROM_VERSION=ROM_7189_DI02 -DUSE_RTOS=1 -DRAM_BANKS_OPTIONAL_MAX=7 -DUSE_FLASH_BOOTLOADER=0 -DENCRYPT_USER_PAYLOAD=0 -DMAX_FLASH_FW_SIZE_SECTORS=2046 -DBHI260_OTP_SENSOR_CALIBRATION -DBHI260_ACCEL_RANGE_OFFSET -DBHI260_GYRO_SENSITIVITY_CORRECTION -DBHI260_GYRO_TIMOSC_PLL -nostartfiles -fno-stack-check -mlong-calls -DBHY2_KLIO_PAGE=9 -D__T7189__ -DDEVICE=0x7189 @"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/common/7189/gcc.arg" -DVERSION=6 -DVERSION_BUGFIX=6 -DVERSION_MAJOR=3 -DVERSION_MINOR=0 -DBUILD_DATE="" -DBUILD_TIME="" -DI2C_QUEUE_SIZE=40 -DCONFIG_HAS_FLOAT_MATRIX=0 -DCONFIG_HAS_BOSCH_EXT_DATA=1 -DLARGE_DECIMATION -DPLACEHOLDER_SENSOR_API -DVIRTUAL_MODE_CHANGE -UVIRTUAL_CURRENT_CONSUMPTION -DVIRTUAL_EXPANSION_DATA -DHAS_ACTUAL_RATE -DINTF_STREAMING -e_start -Wl,--start-group -lm -Wl,--end-group -u gEM7189Config -Wl,-T"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/kernel/kernel-flash-linker.cmd" -u gFwHeader -u gUserEntries -u header_copy_offset -Bdefine:_BUILD_YEAR=2021 -Bdefine:_BUILD_MONTH=4 -Bdefine:_BUILD_DAY=16 -Bdefine:_BUILD_HOUR=13 -Bdefine:_BUILD_MINUTE=26 -Bdefine:_BUILD_SECOND=27 -Bdefine:USER_VERSION=6 -ffunction-sections -fdata-sections -u gFwHeader_copy -Wl,-e -Wl,user_init @"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.lib.inc" @CMakeFiles\user-flash-1ae8a3fe9ff124f08042e312aa3078a6.rsp -o user\user-flash-1ae8a3fe9ff124f08042e312aa3078a6 -Wl,--start-group -Xlinker -Map=user\user-flash-1ae8a3fe9ff124f08042e312aa3078a6.map -Wl,--end-group && cmd.exe /C "cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\bin\initdat -q -Xnocompress user-flash-1ae8a3fe9ff124f08042e312aa3078a6 user-flash-1ae8a3fe9ff124f08042e312aa3078a6 !data !lit !bss .reclaim_data ~.flash_fw_header ~.flash_fw_header_offset ~.vectors ~.flash_fw_header_copy && cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -P C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/cmake/allocations.cmake C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.usage.csv C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.data/libs"" c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: ../libs/MetawarePrintf/libMetawarePrintf.a(_doecvtd.c.obj): in function `_doecvtd': _doecvtd.c:(.text._doecvtd+0x7a): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x7a): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x90): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x90): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xce): undefined reference to `_mwdrdiv_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xce): undefined reference to `_mwdrdiv_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xf4): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xf4): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x11e): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x11e): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x132): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x132): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x140): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x140): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x15a): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x15a): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x16e): undefined reference to `_mwddiv_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x16e): undefined reference to `_mwddiv_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x180): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x180): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x196): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x196): undefined reference to `__dcmpIEEE' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x1fc): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x1fc): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x204): undefined reference to `_mwdtruncu_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x204): undefined reference to `_mwdtruncu_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x20a): undefined reference to `_mwdfltu_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x20a): undefined reference to `_mwdfltu_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x212): undefined reference to `_mwdrsub_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x212): undefined reference to `_mwdrsub_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: ../libs/MetawarePrintf/libMetawarePrintf.a(_pow10d.c.obj): in function `_pow10d': _pow10d.c:(.text._pow10d+0x22): undefined reference to `_mwdmul_' c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _pow10d.c:(.text._pow10d+0x22): undefined reference to `_mwdmul_' collect2.exe: error: ld returned 1 exit status
FAILED: user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6 user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.lib.inccmd.exe /C "cmd.exe /C "cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -E remove C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.usage.csv && cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -P C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/cmake/force_include.cmake 1 C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.lib.inc C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.data/libs C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.data/sections && cd C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build" && C:\arc_gnu\bin\arc-elf32-gcc.exe -mno-sdata -Os -include "C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/common/includes/hw_versions.h" -Werror -Wno-error=deprecated-declarations -g -DROM_NAME=bosch_rom -DROM_VERSION=ROM_7189_DI02 -DUSE_RTOS=1 -DRAM_BANKS_OPTIONAL_MAX=7 -DUSE_FLASH_BOOTLOADER=0 -DENCRYPT_USER_PAYLOAD=0 -DMAX_FLASH_FW_SIZE_SECTORS=2046 -DBHI260_OTP_SENSOR_CALIBRATION -DBHI260_ACCEL_RANGE_OFFSET -DBHI260_GYRO_SENSITIVITY_CORRECTION -DBHI260_GYRO_TIMOSC_PLL -nostartfiles -fno-stack-check -mlong-calls -DBHY2_KLIO_PAGE=9 -D__T7189__ -DDEVICE=0x7189 @"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/common/7189/gcc.arg" -DVERSION=6 -DVERSION_BUGFIX=6 -DVERSION_MAJOR=3 -DVERSION_MINOR=0 -DBUILD_DATE="" -DBUILD_TIME="" -DI2C_QUEUE_SIZE=40 -DCONFIG_HAS_FLOAT_MATRIX=0 -DCONFIG_HAS_BOSCH_EXT_DATA=1 -DLARGE_DECIMATION -DPLACEHOLDER_SENSOR_API -DVIRTUAL_MODE_CHANGE -UVIRTUAL_CURRENT_CONSUMPTION -DVIRTUAL_EXPANSION_DATA -DHAS_ACTUAL_RATE -DINTF_STREAMING -e_start -Wl,--start-group -lm -Wl,--end-group -u gEM7189Config -Wl,-T"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/kernel/kernel-linker.cmd" -u gFwHeader -u gUserEntries -u header_copy_offset -Bdefine:_BUILD_YEAR=2021 -Bdefine:_BUILD_MONTH=4 -Bdefine:_BUILD_DAY=16 -Bdefine:_BUILD_HOUR=13 -Bdefine:_BUILD_MINUTE=26 -Bdefine:_BUILD_SECOND=27 -Bdefine:USER_VERSION=6 -ffunction-sections -fdata-sections -u gFwHeader_copy -Wl,-e -Wl,user_init @"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.lib.inc" @CMakeFiles\user-ram-1ae8a3fe9ff124f08042e312aa3078a6.rsp -o user\user-ram-1ae8a3fe9ff124f08042e312aa3078a6 -Wl,--start-group -Xlinker -Map=user\user-ram-1ae8a3fe9ff124f08042e312aa3078a6.map -Wl,--end-group && cmd.exe /C "cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\bin\initdat -q user-ram-1ae8a3fe9ff124f08042e312aa3078a6 user-ram-1ae8a3fe9ff124f08042e312aa3078a6 !data !lit !bss ~.ram_keys ~.fw_header ~.fw_header_offset ~.em7189_descriptor .phys_sensor_descriptors .virt_sensor_descriptors .timer_sensor_descriptors ~.reclaim ~.vectors ~.fw_header_copy && cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -P C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/cmake/allocations.cmake C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.usage.csv C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-ram-1ae8a3fe9ff124f08042e312aa3078a6.data/libs""c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: ../libs/MetawarePrintf/libMetawarePrintf.a(_doecvtd.c.obj): in function `_doecvtd':_doecvtd.c:(.text._doecvtd+0x7a): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x7a): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x90): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x90): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xce): undefined reference to `_mwdrdiv_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xce): undefined reference to `_mwdrdiv_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xf4): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xf4): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x11e): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x11e): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x132): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x132): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x140): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x140): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x15a): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x15a): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x16e): undefined reference to `_mwddiv_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x16e): undefined reference to `_mwddiv_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x180): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x180): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x196): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x196): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x1fc): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x1fc): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x204): undefined reference to `_mwdtruncu_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x204): undefined reference to `_mwdtruncu_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x20a): undefined reference to `_mwdfltu_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x20a): undefined reference to `_mwdfltu_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x212): undefined reference to `_mwdrsub_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x212): undefined reference to `_mwdrsub_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: ../libs/MetawarePrintf/libMetawarePrintf.a(_pow10d.c.obj): in function `_pow10d':_pow10d.c:(.text._pow10d+0x22): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _pow10d.c:(.text._pow10d+0x22): undefined reference to `_mwdmul_'collect2.exe: error: ld returned 1 exit status[211/246] Linking C executable user\user-flash-c3900fa0ad1864fd0adb9da62d9ca1b0[212/246] Linking C executable user\user-flash-d66927bc6b7229a80953ef99e811472a[213/246] Linking C executable user\user-ram-d66927bc6b7229a80953ef99e811472a[214/246] Linking C executable user\user-ram-97df84ec8122a0de8d6cf3413a289112[215/246] Linking C executable user\user-flash-418c4b99eb6f671a9001c6c1d2106937[216/246] Linking C executable user\user-flash-97df84ec8122a0de8d6cf3413a289112[217/246] Linking C executable user\user-flash-b493b6d7e3aa1f3db1c2d38f9a7e6e59[218/246] Linking C executable user\user-ram-b493b6d7e3aa1f3db1c2d38f9a7e6e59[219/246] Linking C executable user\user-flash-a9d622d876c13cb67a65e15c2cf77d14[220/246] Linking C executable user\user-ram-86bdf125440f2c720d9795b58dc7306f[221/246] Linking C executable user\user-flash-1ae8a3fe9ff124f08042e312aa3078a6FAILED: user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6 user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.lib.inccmd.exe /C "cmd.exe /C "cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -E remove C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.usage.csv && cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -P C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/cmake/force_include.cmake 1 C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.lib.inc C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.data/libs C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.data/sections && cd C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build" && C:\arc_gnu\bin\arc-elf32-gcc.exe -mno-sdata -Os -include "C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/common/includes/hw_versions.h" -Werror -Wno-error=deprecated-declarations -g -DROM_NAME=bosch_rom -DROM_VERSION=ROM_7189_DI02 -DUSE_RTOS=1 -DRAM_BANKS_OPTIONAL_MAX=7 -DUSE_FLASH_BOOTLOADER=0 -DENCRYPT_USER_PAYLOAD=0 -DMAX_FLASH_FW_SIZE_SECTORS=2046 -DBHI260_OTP_SENSOR_CALIBRATION -DBHI260_ACCEL_RANGE_OFFSET -DBHI260_GYRO_SENSITIVITY_CORRECTION -DBHI260_GYRO_TIMOSC_PLL -nostartfiles -fno-stack-check -mlong-calls -DBHY2_KLIO_PAGE=9 -D__T7189__ -DDEVICE=0x7189 @"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/common/7189/gcc.arg" -DVERSION=6 -DVERSION_BUGFIX=6 -DVERSION_MAJOR=3 -DVERSION_MINOR=0 -DBUILD_DATE="" -DBUILD_TIME="" -DI2C_QUEUE_SIZE=40 -DCONFIG_HAS_FLOAT_MATRIX=0 -DCONFIG_HAS_BOSCH_EXT_DATA=1 -DLARGE_DECIMATION -DPLACEHOLDER_SENSOR_API -DVIRTUAL_MODE_CHANGE -UVIRTUAL_CURRENT_CONSUMPTION -DVIRTUAL_EXPANSION_DATA -DHAS_ACTUAL_RATE -DINTF_STREAMING -e_start -Wl,--start-group -lm -Wl,--end-group -u gEM7189Config -Wl,-T"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/kernel/kernel-flash-linker.cmd" -u gFwHeader -u gUserEntries -u header_copy_offset -Bdefine:_BUILD_YEAR=2021 -Bdefine:_BUILD_MONTH=4 -Bdefine:_BUILD_DAY=16 -Bdefine:_BUILD_HOUR=13 -Bdefine:_BUILD_MINUTE=26 -Bdefine:_BUILD_SECOND=27 -Bdefine:USER_VERSION=6 -ffunction-sections -fdata-sections -u gFwHeader_copy -Wl,-e -Wl,user_init @"C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.lib.inc" @CMakeFiles\user-flash-1ae8a3fe9ff124f08042e312aa3078a6.rsp -o user\user-flash-1ae8a3fe9ff124f08042e312aa3078a6 -Wl,--start-group -Xlinker -Map=user\user-flash-1ae8a3fe9ff124f08042e312aa3078a6.map -Wl,--end-group && cmd.exe /C "cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\bin\initdat -q -Xnocompress user-flash-1ae8a3fe9ff124f08042e312aa3078a6 user-flash-1ae8a3fe9ff124f08042e312aa3078a6 !data !lit !bss .reclaim_data ~.flash_fw_header ~.flash_fw_header_offset ~.vectors ~.flash_fw_header_copy && cd /D C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\build\user && C:\Users\Noah\Documents\BHI260AB_SDK_1.1.6\win64\cmake\bin\cmake.exe -P C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/cmake/allocations.cmake C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.usage.csv C:/Users/Noah/Documents/BHI260AB_SDK_1.1.6/build/user/user-flash-1ae8a3fe9ff124f08042e312aa3078a6.data/libs""c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: ../libs/MetawarePrintf/libMetawarePrintf.a(_doecvtd.c.obj): in function `_doecvtd':_doecvtd.c:(.text._doecvtd+0x7a): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x7a): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x90): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x90): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xce): undefined reference to `_mwdrdiv_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xce): undefined reference to `_mwdrdiv_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xf4): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0xf4): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x11e): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x11e): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x132): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x132): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x140): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x140): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x15a): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x15a): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x16e): undefined reference to `_mwddiv_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x16e): undefined reference to `_mwddiv_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x180): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x180): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x196): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x196): undefined reference to `__dcmpIEEE'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x1fc): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x1fc): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x204): undefined reference to `_mwdtruncu_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x204): undefined reference to `_mwdtruncu_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x20a): undefined reference to `_mwdfltu_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x20a): undefined reference to `_mwdfltu_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x212): undefined reference to `_mwdrsub_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _doecvtd.c:(.text._doecvtd+0x212): undefined reference to `_mwdrsub_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: ../libs/MetawarePrintf/libMetawarePrintf.a(_pow10d.c.obj): in function `_pow10d':_pow10d.c:(.text._pow10d+0x22): undefined reference to `_mwdmul_'c:/arc_gnu/bin/../lib/gcc/arc-snps-elf/10.2.0/../../../../arc-snps-elf/bin/ld.exe: _pow10d.c:(.text._pow10d+0x22): undefined reference to `_mwdmul_'collect2.exe: error: ld returned 1 exit status
The specific changes I made were to add the following lines to the end of the board config file:
Spoiler (Highlight to read) 131, 800.000000 # VirtBSXCustomAccelDataSource 132, 800.000000 # VirtBSXLeanDeviceOrientation
131, 800.000000 # VirtBSXCustomAccelDataSource132, 800.000000 # VirtBSXLeanDeviceOrientation
and to add the following lines to ENABLED_DRIVERS in config.7189_di03_rtos_bhi260.cmake:
Spoiler (Highlight to read) VirtBSXLeanDeviceOrientation VirtBSXCustomAccelDataSource
VirtBSXLeanDeviceOrientationVirtBSXCustomAccelDataSource
I'm using BHI260AB SDK version 1.1.6.
