When I start the basic example I get:
Timestamp [ms], raw temperature [⸮C], pressure [hPa], raw relative humidity [%], gas [Ohm], IAQ, IAQ accuracy, temperature [°C], relative humidity [%], Static IAQ, CO2 equivalent, breath VOC equivalent
70, 23.14, 101179.00, 37.06, 46298.00, 25.00, 0, 23.14, 37.06, 25.00, 500.00, 0.50
3070, 23.11, 101173.00, 37.17, 53543.00, 25.00, 0, 23.05, 37.37, 25.00, 500.00, 0.50
After a while it starts to report proper values:
756070, 22.55, 101161.00, 38.09, 97417.00, 21.47, 1, 22.49, 38.22, 23.46, 493.84, 0.49
759069, 22.54, 101157.00, 38.09, 97077.00, 21.47, 1, 22.48, 38.25, 23.46, 493.83, 0.49
762069, 22.54, 101157.00, 38.07, 96460.00, 24.25, 1, 22.48, 38.23, 24.67, 498.69, 0.50
I was wondering what the units and ranges for IAQ, IAQ accuracy, Static IAQ, CO2 equivalent, breath VOC equivalent are?
@ehmeducation wrote:
- For IAQ it seems lower is better? What is the range? best/worst ?
- IAQ accuracy is just a plain 0 or 1 ?
- Static IAQ how is this different from IAQ? Does it have the same 0.0-25.0 range?
Some useful posts to begin with and that should answer most the above:
- CO2 equivalent is in ppm?
- Is breath VOC equivalent the same a TVOC? What unit is this in?
Most of the data below can be found in BSEC's Integration Guide and/or bsec_datatype.h.
