Hello
We've designed a board with various chips on an I²C bus and the only one that doesn't respond is the BNO055. Scanning the bus shows only 3 devices when there should be 4. I've checked that the reset and bootload pins are correctly pulled up and now I don't know what to do next.
I've had two boards assembled and both exhibit the same behaviour. Maybe it's only that the sensors are dead but that would be quite unlucky.
I attach a screenshot of the schematics & PCB design. Nothing fancy but maybe I made a mistake despite double and triple checking.
Nicolas
Thanks for your inquiry. Please check the app note https://www.bosch-sensortec.com/media/boschsensortec/downloads/application_notes_1/bst-bno055-an007.... for more informaiton.
Please check the BNO055 I2C 7-bit slave address in your code and make sure that the MCU you are using supports I2C clock streching which is mentioned on page 91 of BNO055 datasheet.
