    Use of bmi160.h API with PIC Microcnotroller
    Sil
    Hello, i'm new of this forum, i try to use the API of "bmx160.h" files with an 8-bit microcntroller in C- language but there is a declaretion of an array inside a function that needed dinamic allocation of memory.
    In the file attached the array is named "uint8_t temp_buf[temp_len];" and the dimension of array "temp_len" is a parameter passed to the function.
    The compiler give me this error: "BMX160_drivers/bmi160.c:1369:21: error: variable length arrays are not supported" .
    Does anyone know what needs to be done to make the compiler allocate memory?
    Thank you!
    6 REPLIES 6
    kilohercas
    Re: Use of bmi160.h API with PIC Microcnotroller
    I was about to create thread with same error. in BMI085 API, i get two errors while compiling, by dynamicly alocating array in wrong way.
    static int8_t get_regs(uint8_t reg_addr, uint8_t *reg_data, uint32_t len, struct bmi08x_dev *dev)
    int8_t rslt = BMI08X_OK;
    uint16_t index;
    uint32_t temp_len = len + dev->dummy_byte;
    uint8_t temp_buff[temp_len]; //Error[Pe028]:temp_len expression must have a constant value
    Sil
    Hello Kilohercas, thank you for your post.
    I tried to identify the maximum number of registers that the array could contain: the registers of the BMX160 device are 126, for safety I added 16 bytes so I declared that vector as "static uint8_t temp_buf [142];" this allows it to compile but i have yet to try if it works. Has anyone ever tried to do it this way?
    kilohercas
    in C, you can do like this:
    uint8_t *pointer;
    pointer = malloc(temp_len * sizeof(uint8_t ));
    I guess it's right way to do it.
    Sil
    I have discovered that can't use malloc () and free () on 8-bit microcontrollers family as describe in the page of compiler manual attached. Now i think to migrate an 32-bit Microchip microcontroller to obtain more memory space.
    Thanks anyway
