    Using BHI260
    Using BHI260
    amoniev
    I am going to use the BHI260 and have a few questions on how to use it:
    How can a HIRQ host interrupt in BHI260 be generated from a timer, that is, at a predetermined time interval.
    Is it possible to work directly with BHI260 hardware timers.
    The SDK has step drivers (VirtStepDetector and VirtStepCounter). How are they configured?
    The SDK has a gesture driver (VirtBSXGlanceGesture). How does it adjust to the desired gesture?
    Hello amoniev,
    Do you use BHI260AB?
    amoniev
    I don't use BHI260 yet. I am considering the possibility of using it.
    Hello amoniev,
    Please refer the following reply:
    In SDK, HIRQ is occupied by system to trigger when wakeup/non-wakeup/debug&status FIFO has data to report or reset happens. So it will has conflict if user operate that GPIO pin in code.
    NO, the hardware timer interface is not published In SDK.
    Not published in customer SDK.
    Internally we can customize it. refer BMI160 0x7A 7B
    Not configurable. The gesture defined by BST specification. And it's dedicated for Android "GlanceGesture".
    Hello. Thanks for the detailed answer. Please explain your answer on VirtStepDetector and VirtStepCounter drivers. The BHI260 has registers 0x7A 0x7B available to define step sensitivity, as described in the Data sheet on BMI160?
