02-23-2022 12:44 PM
Hi Team,
I am using existing BLE to integrate your BME68x sensor via I2C mode. Will there be any problem to include or add the driver and your application,
Please find the feature of our BLE:
could i read the raw information atleast from i2c registers?
Kumar
03-10-2022 08:40 AM
Hi Robin,
The same related to my Cortex-M33 platform, Other person have successfully implemented using your BSEC1 on BME680.
Please check the below thread:
Solved: temperature values is always 0 (bosch-sensortec.com)
Kumar
03-15-2022 10:00 AM
Hello franciskumar200,
How come other person Mr. JimitP have suucess with old version with the source of "bsec_iot_example.c".
reply: "bsec_iot_example. C" is an example of bsec1. If bme680 is used, you can refer to it.
'Is this the library is compatible with the flags. "arm-none-eabi-gcc -mcpu=cortex-m33 -mthumb -mfpu=fpv5-sp-d16 -mfloat-abi=hard
Reply: There was platform and compiler support list, you could check it from the list.You can also use your compiler to try whether the compilation passes or not?
https://www.bosch-sensortec.com/media/boschsensortec/downloads/bsec/bsec1_binary_size_information.pd...
By the way, what sensor part you used? BME680, BME688?
Under what compiler do you want to compile?
03-15-2022 03:06 PM
Hi Robin,
Yes, I am using BME688 with "arm-none-eabi-gcc" compiler.
I am not clear with BEC2 calling in my main application, I understand the BEC1 algo to call the program with our i2c interface rae and write calls with reference code.
Do you have any application skide these values can convert in desktop software? I mean i amable to get the RAW values without using your BSEC algo. Can i apply your bsec algo from application end?
Kumar
03-28-2022 07:59 AM
Hi Robin,
I tried with other libraries, but there are still some issues.
Is there any desktop standalone application which I can forward my GAS raw values to your BEC library? Will it give the GAS results?
For example i am getting RAW values for GAS = 856789 ohm. should i get the actual GAS index in ppm while i pass this value to your BEC lib.
Kumar
04-11-2022 09:46 AM
Except for the software on the official website and GitHub, we have no other software.
