    algobsec for raspberry pi 3 running Ubuntu 64-bit
    arkadi
    Hello, I'm building a binary for BME680 on Ubuntu Bionic 64-bit on Raspberry Pi 3. When linking to libalgobsec.a library from BSEC_1.4.7.4_Generic_Release\algo\normal_version\bin\RaspberryPI\PiThree_ArmV8-a-64bits folder, I get an error:
    gcc -O3 -o bsec bsec.c -li2c -L . -l:libalgobsec.a
    /usr/bin/ld: skipping incompatible ./libalgobsec.a when searching for -l:libalgobsec.a
    Any ideas?
    PS. When I extract the members from the library and check them, it shows 32-bit, not 64! Where would I get 64-bit library then?
    ar x libalgobsec.a
    file bsec_codegen_data.o
    bsec_codegen_data.o: ELF 32-bit LSB relocatable, ARM, EABI5 version 1 (SYSV), not stripped
    20 REPLIES 20
    Vincent
    I will work with engineer team to give you a special lib version with 64 bits supported.
    Great, thank you, waiting for 64-bit version then.
    Vincent
    Here is the version for you.
    Please check it in your platform.
    Hm... sorry but it's the same 32-bit library...
