10-22-2019 10:05 AM
I am looking for an analog, temperature compensated pressure sensor with 3.3V VCC. The output voltage must be between 0-5V. To use it with an arduino. I need a pressure range from 500 mBar to 2 Bar absolute Pressure. So a slight vacuum to a slight overpressure. I want to record the pressure in bottles which are filled with ethanol with a temperature profile from 20-60°C.
10-23-2019 11:33 AM - edited 10-23-2019 11:36 AM
I recommend you consider BMP388 .You can get the relevant information of our pressure sensor from https://www.bosch-sensortec.com/bst/products/all_products/bmp388
And download the API from Github https://github.com/BoschSensortec/BMP3-Sensor-API
