07-25-2022 09:13 PM
As configured the bme688 kit saves files in .csv format but the manual wants.bmerawdata format. Changing the csv file name does not correct the inability to import data. Any suggestions? Changing the saved file format in the Arduino code also does not allow importation. Stopped at square1
08-05-2022 04:36 PM
I have found the solution to this problem which is to use flash.bat rather than library examples to program the Featherboard. The extension .BMERAWDATA seems available through this programming but not in the library examples. The .CSV examples are useful to have available for other types of analysis. Thanks for your input.
