    bno055 linux api
    bno055 linux api
    b0hne
    I am trying to use the bno055 files on GitHub on a nanopi board running armbian.
    I have implemented read write and delay functions to the best of my knowledge, but every readout returns a 0.
    Could anyone tell me where I went wrong?
    The code is:
    #include <iostream>
    #include <unistd.h>
    #include <sys/ioctl.h>
    #include <errno.h>
    #include <stdio.h>
    #include <fcntl.h>
    #include <unistd.h>
    #include <linux/i2c-dev.h>
    #include <syslog.h>
    #include <inttypes.h>
    #include <cstring>
    #include <linux/i2c.h>
    extern "C"
    #include "BNO055_driver/bno055.c"
    #include "BNO055_driver/bno055.h"
    #define BUFFER_SIZE 0x01
    using namespace std;
    s8 BNO055_I2C_bus_read(u8 dev_addr, u8 reg_addr, u8 *reg_data, u8 cnt)
    const char *path = "/dev/i2c-0";
    int fd;
    if (fd != -1)
    if ((fd = open(path, O_RDWR)) < 0)
    return (1);
    if (ioctl(fd, I2C_SLAVE, dev_addr) < 0)
    close(fd);
    return (1);
    char buff[BUFFER_SIZE];
    buff[0] = reg_addr;
    if (write(fd, buff, BUFFER_SIZE) != BUFFER_SIZE)
    close(fd);
    return (1);
    if (read(fd, &reg_data, cnt) != cnt)
    close(fd);
    return (1);
    close(fd);
    return 0;
    s8 BNO055_I2C_bus_write(u8 dev_addr, u8 reg_addr, u8 *reg_data, u8 cnt)
    int fd;
    if (fd != -1)
    return 1;
    close(fd);
    return 1;
    char buff[cnt + 1];
    buff[0] = reg_addr;
    memcpy(&buff[1], reg_data, cnt);
    if (write(fd, buff, cnt + 1) != cnt + 1)
    close(fd);
    return 1;
    close(fd);
    return 0;
    void sleep_ms(unsigned int milliseconds)
    struct timespec ts;
    ts.tv_sec = milliseconds / 1000;
    ts.tv_nsec = (milliseconds % 1000) * 1000000;
    nanosleep(&ts, NULL);
    s8 I2C_routine(bno055_t *bno055)
    bno055->bus_write = BNO055_I2C_bus_write;
    bno055->bus_read = BNO055_I2C_bus_read;
    bno055->delay_msec = sleep_ms;
    bno055->dev_addr = BNO055_I2C_ADDR1;
    return BNO055_INIT_VALUE;
    int main()
    struct bno055_t myBNO;
    I2C_routine(&myBNO);
    cout << "bno055_init " << endl;
    s8 ans = bno055_init(&myBNO);
    cout << "true " << (((s8)0) == ans) << endl;
    u8 chip_id_u8;
    bno055_read_chip_id(&chip_id_u8);
    cout << "chip_id_u8 " << (int)chip_id_u8 << endl;
    2 REPLIES 2
    b0hne
    I think i finally fixed it:
    in s8 BNO055_I2C_bus_read:
    no * in
    if (read(fd, reg_data, cnt) != cnt)
    Hello b0hne,
    You should adapt BNO055_I2C_bus_read() function implement into your platform when you migrate BNO055 driver code to your platform.
    After migration, you could read chip ID to verify read funtion is correct or not.
