12-30-2019 10:18 AM
运用bsec库中的bsec_iot_example.c文件中的return_values_init bsec_iot_init(float sample_rate, float temperature_offset, bme680_com_fptr_t bus_write,
bme680_com_fptr_t bus_read, sleep_fct sleep, state_load_fct state_load, config_load_fct config_load)函数,通过加载测试函数会发现程序在bsec_init()函数会进入hardfault中断,不明白是什么原因,编译软件keil,编译器armcc,芯片stm32f103是m3的,加载通用库的m3中的.lib;后面还进行单独运用bme680_bsec_update_subscription函数,但是会返回-12状态,想问一下回事什么原因导致的
01-08-2020 10:14 AM
For -12 error, when calling bme680_bsec_update_subscription, it means the sample_rate of the requested output (virtual) sensor passed to bsec_update_subscription() does not match with the sampling rate allowed for that sensor.
As for hardfault when calling bsec_iot_init, developers shall make sure all the parameters are right, especially pay attention to the function pointers(related to the MCU platform). Our example bsec_iot_example.c is just reference, can not be directly used in different kind of MCU, developer need to modify it according to his own MCU platform.
Below link explains hardfault:
https://www.iar.com/support/tech-notes/debugger/debugging-a-hardfault-on-cortex-m/
01-14-2020 08:17 AM
谢谢您的回复,关于初始化失败的问题已解决,通过调整尺寸大小就可以了,但是目前又遇到了新的问题,初始化成功后,第一次会得到第一次iaq值0x19,后面再很长冲突会一直得到0x19,时间间隔由长变短,直到数据发生变化,本以为已正常,没想到后面数值会变为0x00,并连续不再发生变化,不知道是什么原因?附件是iaq数据,最前面的3组0x00是初始化的数据,表示初始化正常
4 weeks ago
How did you solved?
I always get hardfault error in this fucntion.
/* Initialize BSEC library */
ret.bsec_status = bsec_init();
4 weeks ago
Hi paengpd,
Could we know some information first from you:
1.What is about your host platform?
2.Which program language you used?
3.What outputs do you need to use from BSEC?
