    could i use the function BSX_S8 bsx_get_gyrocordata_rps(ts_dataxyzf32*) in BSXLITE fusion library
    blues
    hi,could i use the function BSX_S8 bsx_get_gyrocordata_rps(ts_dataxyzf32*) in BSXLITE fusion library ?
    and i find that ts_dataxyzf32* is  in BsxLibraryDataTypes.h.
    /*struct ts_dataxyzf32*/
    /*brief 3-axis data as F32*/
    typedef struct{
    BSX_F32 x; /**< x-axis data */
    BSX_F32 y; /**< y-axis data */
    BSX_F32 z; /**< z-axis data */
    }ts_dataxyzf32;
    but i find other functions that  also use 'ts_dataxyzf32*'in BSXLITE fusion library,such as BSX_S8 bsx_get_acccordata(ts_dataxyzf32*);
    how can i distinguish between them?
    could i use them directly?
    thanks
    6 REPLIES 6
    i think the range is from -2g  to 2g m/s2.
    so if the data is 32768,and the output is 2g m/s2.
    right?
    Vincent
    It is depending on the physical sensor setting.
    If you set the sensor to 2G range,  then the lib output full range is +-2G.
    If you set the sensor to 4G range,  then the lib putput full range is +-4G.
    BSX lite is just calculation the sensor data
