08-06-2020 08:19 AM
The BME680 alone can only output raw temperature, absolute pressure, relative humidity, and gas resistance.
How can I calculate CO2 equivalent and VOC without the library?
I did not find any formula neither in the BME680 datasheet nor in the API.
I am using PIC32MX370/470 MCU.
Best regards
Ankur
08-06-2020 10:56 PM
If you need the CO2 equivalent and VOC (IAQ index) output, you must use our BSEC lib.
The BME680 only output gas register value. Without lib, we can't compensate it and output your desired value.
If your MCU is not included in the support list of our BSEC pre compiled lib, you can leave your compiler details here.
Then we can try to build a special BSEC lib version for you.
08-07-2020 11:07 AM
Below are the details:
MCU detailed type: PIC32MX370F512H and PIC32MX470F512H Curiosity Board
IDE version: MPLAB X IDE v5.40
Compiling option: XC32 v1.43
Thank you
08-07-2020 06:46 PM - edited 08-07-2020 06:46 PM
Yes, we will try to build a lib for you.
Did you use any special compiler parameters in your project?
08-08-2020 06:33 AM
Kindly suggest which type of special compiler parameter you are asking for.
Thank you
