03-30-2021 08:26 AM
Hello ALL,
I started to use bma accel sensor. I need to activate fifo to get right accel data. I have used my custom board which based on TI cc1310.
Is there any source code to activate/use fifo which I can reference.
I am also reading bma400 datasheet. there is some procedure which has to be done to activate sensor . If I use fifo mode, is this starting procedure gonna change? or it is gonna stay same.?
BR
Bekir
03-30-2021 08:31 AM
03-30-2021 02:52 PM
Hello
thank you for the reply.
I have done some setting for bma400 to get accurate acceleration data as below.
When I run the code with this setting, the acceleration data that I see on debug is changing every second however I dont change the position of the sensor
Did I forget something to add?
thank you.
03-30-2021 03:47 PM
the data that I see on debug as below . But every second lsbx, lsby,lsbz data is changing without any movement
Do you think that This changing is normal? How to make sure that I get accurate values ? if I miss something about setting, can you tell me which part has to fix ?
thank you
03-30-2021 03:55 PM
You can see that how I get all accel data as below.
