03-30-2021 08:26 AM
Hello ALL,
I started to use bma accel sensor. I need to activate fifo to get right accel data. I have used my custom board which based on TI cc1310.
Is there any source code to activate/use fifo which I can reference.
I am also reading bma400 datasheet. there is some procedure which has to be done to activate sensor . If I use fifo mode, is this starting procedure gonna change? or it is gonna stay same.?
BR
Bekir
03-31-2021 07:09 AM
From example code fifo_watermark_xyz_data.c, we use rslt = bma400_get_fifo_data() to get fifo data, and then bma400_extract_accel() extract the fifo data to x/y/z axis data.
Please gradually try to check this example code.
Best regards.
