    issue when reading BME680
    arnaud
    Hello everyone,
    I am trying to use a BME680 with this library : https://github.com/BoschSensortec/BME680_driver
    I don't want to use an other one because this library doesn't use arduino.h and I would like to use this code for an other MCU.
    So the code detect if a sensor is plug. But when I am reading I have the value 0 so everything should be OK but the measure don't move they are fix.
    here is my code hope someone could help me :
    #include <Wire.h>
    #include"bme680.h"
    //#define BME680_DEBUG
    struct bme680_dev gas_sensor;
    int8_t user_i2c_read (uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len){
      int result=0;
      Wire.beginTransmission(dev_id);
      Wire.write(reg_addr);   // Accès au registre
      Wire.endTransmission(false);
      Wire.requestFrom(dev_id, len);
      if (len<=Wire.available()){
        for(int i=0;i<len;i++){
            data[i] = Wire.read();
      }else{
        result=5;
      return result;
     * Write the content into the register targeted register for a specified device
     * Parameter :
     *    dev_id : the I2C adress of the device
     *    reg_addr : the adresse of the targeted register
     *    *data : pointer to the data to write
     *    len : number in byte of the data
     * Return:  Error code
    int8_t user_i2c_write (uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len){
      int result=0;
        Wire.write(data[i]);
      Wire.endTransmission();
      return result;
     * function to wait the time
     * Parameter :
     *    period : time that will be waited in millisecond
    void user_delay_ms (uint32_t period){
      delay(period);
    int8_t rslt = BME680_OK;
    void init_bme (void)
        /* Select the power mode */
            | BME680_GAS_SENSOR_SEL;
        rslt = bme680_set_sensor_settings(set_required_settings,&gas_sensor);
        /* Set the power mode */
    void setup() {
      Serial.begin(9600);
        init_bme();
        gas_sensor.dev_id = BME680_I2C_ADDR_SECONDARY;
        gas_sensor.read = user_i2c_read;
        gas_sensor.write = user_i2c_write;
        gas_sensor.delay_ms = user_delay_ms;
        /* amb_temp can be set to 25 prior to configuring the gas sensor
         * or by performing a few temperature readings without operating the gas sensor.
        gas_sensor.amb_temp = 25;
        Wire.begin();
        Serial.println(rslt);
    void loop() {
      // put your main code here, to run repeatedly:
      uint16_t meas_period = 10000 ;
        while(1){
      delay(meas_period);
      Serial.print ("T : ");
      Serial.print(data.temperature / 100.0);
      Serial.print ("P : ");
      Serial.print(data.pressure / 100.0);
      Serial.print ("H :");
      Serial.println(data.humidity / 1000.0);
      /* Avoid using measurements from an unstable heating setup */
      if (data.status & BME680_GASM_VALID_MSK)
        Serial.print("G: ");
        Serial.print(data.gas_resistance);
        Serial.println("Kohms");
      /* Trigger the next measurement if you would like to read data out continuously */
      if (gas_sensor.power_mode == BME680_FORCED_MODE) {
    2 REPLIES 2
    Vincent
    You should put init_bme() after bme680_init.
    thank you very much !
