    problem of bxslite library
    sunnyYang
    Hi Professors,
    1、Can Bsxlite be used on bmi088 device?
    2、 What is the accelspec/algospec/magspec  about bmi088 in bsxlite?
    3、The bsxlite ODR is 100Hz ,what is the input data rate?
    4、Where can I get Bsx full?
    fish
    Re: problem of bxslite library
    BSXlite support 9-axis, so you need prepare a/g/m sensor data. If you only need IMU fusion, please use BSX-Full.
    If you download BSXlite algo, you could find the relative guildline about using this algo. So what's the accelspec/algospec/magspec means?
    ODR is sensor's output data rate, directly feed to fusion algorithm.
    You could contact local distributor.
