    reason for changing bus communication function pointers
    rey-a
    I'm working with a BMI270 and its GitHub library. I noticed a important change with the release v.2.46.1. (File bmi2_defs.h)
    The old typedef function pointer for the bus interfacing was:
    typedef int8_t (*bmi2_read_fptr_t)(uint8_t dev_addr, uint8_t reg_addr, uint8_t *data, uint16_t len);
    this instruction has been modified to:
    typedef BMI2_INTF_RETURN_TYPE (*bmi2_read_fptr_t)(uint8_t reg_addr, uint8_t *reg_data, uint32_t len, void *intf_ptr);
    I don't fully understand the interest of such a change... Because now the device address must be passed through the pointer *intf_ptr ... I find it much less clear. There's probably a good reason for this change but I don't understand it.
    If someone can help me...
    Minhwan
    Hello rey-a,
    If you are using i2c, you should put dev id in interface as below.
    i2c_bus = BMI2_I2C_PRIM_ADDR;
    bmi2.intf_ptr = &i2c_bus;
    bmi2.intf = BMI2_I2C_INTF;
    bmi2.read = bmi2xy_hal_i2c_bus_read;
    bmi2.write = bmi2xy_hal_i2c_bus_write;
    /*! This API is used to perform I2C read operation with sensor */
    int8_t bmi2xy_hal_i2c_bus_read(uint8_t reg_addr, uint8_t *reg_data, uint32_t length, void *intf_ptr)
    int8_t rslt = 0;
    //uint8_t dev_id = 0x68;
    uint8_t* dev_id = (uint8_t *)intf_ptr;
    rslt = BMI270_read_i2c(*dev_id, reg_addr, reg_data, length);
    return rslt;
    /*! This API is used to perform I2C write operations with sensor */
    int8_t bmi2xy_hal_i2c_bus_write(uint8_t reg_addr, const uint8_t *reg_data, uint32_t length, void *intf_ptr)
    int8_t rslt = 0;
    // uint8_t dev_id = 0x68;
    rslt = BMI270_write_i2c(*dev_id, reg_addr, (uint8_t *)reg_data, length);
    return rslt;
    If you are using spi and doesn't use several slave, but only bmi270, you don't need to use it. ( It's for chip selection )
    But, anyway you need to put it as below.
    #define BMI260_CS 10
    spi_bus = BMI260_CS;
    bmi2.intf_ptr = &spi_bus;
    bmi2.intf = BMI2_SPI_INTF;
    bmi2.read = BMI270_read_spi;
    bmi2.write = BMI270_write_spi;
    My question wasn't about the way to use it but on the reason of this changement. So if I understand it correctly, it has been changement to use the same variable (a void pointer) to use it as I2C or SPI parameter depending on the bus used.
    I found the parameter badly adapted to transmit the i2c address, but now it's make sense.
    Thanks for your response.
    Minhwan
    Hello rey-a,
    Its intention could be flexibility. Using void paramater, it can get any type of value as parameter.
    Yap, but it could be confusing for old user, and some people.
    Thanks 🙂
