    strange BME680 gas part behavior
    wkwj
    I have encountered a strange behavior of BME680 multivariable sensor(s) (as it happened to all 3 pieces I have). The sensor is correctly supplied (3,3 V, no voltage sags, both VDD and VDDIO pins shorted together, low impedance GND connection) and interfaced via I2C (communication 100% correct).
    When I measure temperature, humidity and pressure the sensor triggers correctly and the response obtained via I2C is very accurate. But when gas sensing feature is enabled (via RUN_GAS bit in CTRL_GAS_1 register) the sensor behaves in a strange way. The  0th gas sensor heater set point is used, heater temperature and heating time registers contain:
    GAS_WAIT_0 10111110
    RES_WAIT_0 11010000
    When MODE bit in CTRL_MEAS register is set to 1 the sensor correctly sets MEASURING flag in MEAS_STATUS_0 register to 1. But then, after approx. 11 ms some registers are set to 11111111 and then, after another 3,8 ms (it is the fastest time graduation I was able to obtain to log register states) gas-related registers are reset to 0. Here is the log of gas-sensing-related registers:
    CTRL_GAS_1
    IDAC_HEAT_0
    GAS_R_LSB
    GAS_WAIT_0
    RES_WAIT_0
    CTRL_MEAS
    MEAS_STATUS_0
    10000
    0
    100
    10111110
    11010000
    100101
    100000
    10000
    0
    100
    10111110
    11010000
    100101
    100000
    11111111
    11111111
    11111111
    11111111
    11111111
    11111111
    0
    0
    0
    100
    0
    0
    0
    0
    0
    0
    100
    0
    0
    0
    0
    I was also monitoring the sensor supply current using a wideband current clamp probe and a scope but  no current jump, related to heater turn-on was registered.
    Any idea what is happening ? Any help or suggestion would be highly appreciated.
    Best regards,
    Pawel
    o_o
    Contributor
    My best suggestion is to not worry with the register values too much, and to simply use the Sensor API : https://github.com/BoschSensortec/BME680_driver
    Simply provide i2c read and write functions, and a delay function. Especially if you plan on using BSEC later on, the Sensor API is a must.
    o_o
