Hi Minhwan,
I tried to compile with your BSEC library on my platform, which gives Flash overflow because your library and application code consumes more memory.
That's why I wasn't able to test the whole thing.
Regards,
Kumar
Hi Kumar,
Thanks for letting me know.
Hi Minhwan,
Still not sorted out my problem.
Integrating with libraray is giving memeory related issue? is there any functional calls cacn reduce the code or optimize?
REgards,
Kumar
Wow, thank you for your answer, which also helped me!
Hi Kumar,
Sure, if you want to use our library, you need some amount of space.
And unfortunately, you need enough space for our library. There is no reduced version of library for BSEC.
