04-22-2023 09:12 PM
Good evening.
The datasheet for the BMI160 seems to specify the zero-g offset for the 8g range. Is there any data/specification available for the 2g range? Can the 2g range values simply be dereived from the 8g values given in the datasheet?
Thank you!
04-23-2023 12:28 PM
Hi peterl,
The offset in the data sheet only tests for 8g range, but you can configure your sensor to 8g range and test the offset to see if the offset is within the range described in the data sheet, and then configure the sensor to 2g range and measure the offset.
