    Pull up or pull down register when the BMI160 INT pin is configured to open drain?
    Accepted Solution
    elrhoul
    Long-established Member
    How to use the Pull up / pull down register when the sensor INT pin is configured to open drain?
    Tags (3)
    View Entire Topic
    elrhoul
    It depends  which active mode is chosen:
    • High active  -->  you should put pull down resistor
    • Low active   -->  you should put pull up resistor
    The resistor value should depend on the target platform. In general , 2.2KΩ or 4.7KΩ can be used.
