I am designing a new device which needs an IMU that outputs orientation quaternions at a high rate (1KHz).
I have been reviewing your motion sensing devices, but I can't come up with a solution that complies with both requirements.
Do you think either the BMF055 or the BNO055 could achieve those speeds?
If not, do you have any solution for the required specs? Maybe using multiple sensors and fusing their data in another microcontroller with your fusion library or something.
Thanks in advance,
