Accuracy of BME280 in high range of humidity
 I want to use a Bosch Sensortec BME280 for my job.
However I need to use this sensor in high range of humidity (more than 80% of relative humidity).
So, I would like to know if the accuracy of the sensor changes when the humidity is very high during a few hours, especially when it is a condensing environment (100% of Relative Humidity).
Best reply by Inactive Member
The datasheet should cover all the available specifications of the sensor. If your specific conditions are not covered in the datasheet, we typically also cannot publish such data elsewhere either.
