Hello, I have a problem to calibrate BHI260AP.
I got the calibration profile with uint8_t array from bhy2_get_calibration_profile.
I tried to adapt the calibration to the sensor before getting data, but it looks that it doesn't work.
The reason that I say like it is,
The arrays from bhy2_get_calibration_profile "before bhy2_set_calibration_profile" and "after bhy2_set_calibration_profile" is same.
And the adapted calib_profile and the array "after bhy2_set_calibration_profile" is different. I thought that those two must be same before getting data.
I leave the code under the question. calib_acc is calib profile to adapt, readed_acc is sensor's profile after adapted.
I modified the example quartonian.c
How can I solve this problem?
Best regard,
setup_interfaces(true, intf); /* Perform a power on reset */
printf("INITIALIZE BHY\n");
#ifdef BHY2_USE_I2C
rslt = bhy2_init(BHY2_I2C_INTERFACE, bhy2_i2c_read, bhy2_i2c_write, bhy2_delay_us, BHY2_RD_WR_LEN, NULL, &bhy2);
#else
rslt = bhy2_init(BHY2_SPI_INTERFACE, bhy2_spi_read, bhy2_spi_write, bhy2_delay_us, BHY2_RD_WR_LEN, NULL, &bhy2);
#endif
printf("INITIALIZE BHY ERR %d\n",rslt);
print_api_error(rslt, &bhy2);
rslt = bhy2_soft_reset(&bhy2);
printf("bhy2_soft_reset %d\n", rslt);
rslt = bhy2_get_product_id(&product_id, &bhy2);
printf("bhy2_get_product_id %d\n", rslt);
/* Check for a valid product ID */
if (product_id != BHY2_PRODUCT_ID)
printf("Product ID read %X. Expected %X\r\n", product_id, BHY2_PRODUCT_ID);
else
printf("BHI260/BHA260 found. Product ID read %X\r\n", product_id);
/* Check the interrupt pin and FIFO configurations. Disable status and debug */
hintr_ctrl = BHY2_ICTL_DISABLE_DEBUG;
hintr_ctrl = 0;
rslt = bhy2_set_host_interrupt_ctrl(hintr_ctrl, &bhy2);
rslt = bhy2_get_host_interrupt_ctrl(&hintr_ctrl, &bhy2);
printf("Host interrupt control\r\n");
printf(" Wake up FIFO %s.\r\n", (hintr_ctrl & BHY2_ICTL_DISABLE_FIFO_W) ? "disabled" : "enabled");
printf(" Non wake up FIFO %s.\r\n", (hintr_ctrl & BHY2_ICTL_DISABLE_FIFO_NW) ? "disabled" : "enabled");
printf(" Status FIFO %s.\r\n", (hintr_ctrl & BHY2_ICTL_DISABLE_STATUS_FIFO) ? "disabled" : "enabled");
printf(" Debugging %s.\r\n", (hintr_ctrl & BHY2_ICTL_DISABLE_DEBUG) ? "disabled" : "enabled");
printf(" Fault %s.\r\n", (hintr_ctrl & BHY2_ICTL_DISABLE_FAULT) ? "disabled" : "enabled");
printf(" Interrupt is %s.\r\n", (hintr_ctrl & BHY2_ICTL_ACTIVE_LOW) ? "active low" : "active high");
printf(" Interrupt is %s triggered.\r\n", (hintr_ctrl & BHY2_ICTL_EDGE) ? "pulse" : "level");
printf(" Interrupt pin drive is %s.\r\n", (hintr_ctrl & BHY2_ICTL_OPEN_DRAIN) ? "open drain" : "push-pull");
/* Configure the host interface */
hif_ctrl = 0;
rslt = bhy2_set_host_intf_ctrl(hif_ctrl, &bhy2);
/* Check if the sensor is ready to load firmware */
rslt = bhy2_get_boot_status(&boot_status, &bhy2);
if (boot_status & BHY2_BST_HOST_INTERFACE_READY)
upload_firmware(boot_status, &bhy2);
rslt = bhy2_get_kernel_version(&version, &bhy2);
if ((rslt == BHY2_OK) && (version != 0))
printf("Boot successful. Kernel version %u.\r\n", version);
rslt = bhy2_register_fifo_parse_callback(BHY2_SYS_ID_META_EVENT, parse_meta_event, NULL, &bhy2);
rslt = bhy2_register_fifo_parse_callback(BHY2_SYS_ID_META_EVENT_WU, parse_meta_event, NULL, &bhy2);
rslt = bhy2_register_fifo_parse_callback(QUAT_SENSOR_ID, parse_quaternion, NULL, &bhy2);
rslt = bhy2_get_and_process_fifo(work_buffer, WORK_BUFFER_SIZE, &bhy2);
else
printf("Host interface not ready. Exiting\r\n");
close_interfaces(intf);
return 0;
char* file_acc = "/home/unistrrel/COINES/v2.7.0/examples/bhy2/examples/euler_cal/calib_acc_f.txt";
char* file_gyro = "/home/unistrrel/COINES/v2.7.0/examples/bhy2/examples/euler_cal/calib_gyro_f.txt";
char* file_mag = "/home/unistrrel/COINES/v2.7.0/examples/bhy2/examples/euler_cal/calib_mag_f.txt";
char* file_sic = "/home/unistrrel/COINES/v2.7.0/examples/bhy2/examples/euler_cal/sic_mat_f.txt";
FILE* f_acc;
FILE* f_gyro;
FILE* f_mag;
FILE* f_sic;
f_acc = fopen(file_acc, "r");
f_gyro = fopen(file_gyro, "r");
f_mag = fopen(file_mag, "r");
f_sic = fopen(file_sic, "r");
char read_acc[300];
char read_gyro[1000];
char read_mag[2000];
char read_sic[300];
fgets(read_acc, 300, f_acc);
fgets(read_gyro, 1000, f_gyro);
fgets(read_mag, 2000, f_mag);
fgets(read_sic, 300, f_sic);
fclose(f_acc);
fclose(f_gyro);
fclose(f_mag);
fclose(f_sic);
char* mat_acc = strtok(read_acc, " ");
for (int i = 0; i < 72; i++) {
calib_acc[i] = atoi(mat_acc);
mat_acc = strtok(NULL, " ");
char* mat_gyro = strtok(read_gyro, " ");
for (int i = 0; i < 200; i++) {
calib_gyro[i] = atoi(mat_gyro);
mat_gyro = strtok(NULL, " ");
char* mat_mag = strtok(read_mag, " ");
for (int i = 0; i < 408; i++) {
calib_mag[i] = atoi(mat_mag);
mat_mag = strtok(NULL, " ");
char* mat_sic = strtok(read_sic, " ");
calib_sic[i] = atoi(mat_sic);
mat_sic = strtok(NULL, " ");
rslt = bhy2_set_calibration_profile(BHY2_PHYS_SENSOR_ID_ACCELEROMETER, calib_acc, 72, &bhy2);
rslt = bhy2_set_calibration_profile(BHY2_PHYS_SENSOR_ID_GYROSCOPE, calib_gyro, 200, &bhy2);
rslt = bhy2_set_calibration_profile(BHY2_PHYS_SENSOR_ID_MAGNETOMETER, calib_mag, 408, &bhy2);
rslt = bhy2_set_sic_matrix(calib_sic, 72, &bhy2);
/* Update the callback table to enable parsing of sensor data */
rslt = bhy2_update_virtual_sensor_list(&bhy2);
float sample_rate = 100.0; /* Read out data measured at 100Hz */
uint32_t report_latency_ms = 0; /* Report immediately */
rslt = bhy2_set_virt_sensor_cfg(QUAT_SENSOR_ID, sample_rate, report_latency_ms, &bhy2);
uint8_t init_readed_acc[72];
uint32_t act_len = 200;
uint8_t readed_acc[72];
rslt = bhy2_get_calibration_profile(BHY2_PHYS_SENSOR_ID_ACCELEROMETER, init_readed_acc, 72, &act_len, &bhy2);
rslt = bhy2_get_calibration_profile(BHY2_PHYS_SENSOR_ID_ACCELEROMETER, readed_acc, 72, &act_len, &bhy2);
printf("[%d]: %d %d\n", i, calib_acc[i], readed_acc[i]);
