BHI260AP Shuttle Board 3.0 Kernel Version is 0
I am trying to bring up the BHI260AP Shuttle Board 3.0 at 1.8V using I2C with nrf52840DK.
I had issue that I got kernel version value 0 from the call bhy2_get_kernel_version(&version, &bhy2), so basically I didnt get "printf("Boot successful. Kernel version %u.\r\n", version);".  But I thought I had successfully uploaded the firmware to the ram since the boot_status is 0x31 from the call bhy2_boot_from_ram(&bhy2).
What could be the problem?
My BHI260AP Shuttle Board 3.0 setup:
VDD -> 1.8V
VDDIO -> 1.8V
APP_SPI_CS -> 1.8V
APP_SCL -> nrf52840DK SCL with external pull up resistor 4.7k
APP_SPI_MISO -> GND
APP_SDA -> nrf52840DK SDA with external pull up resistor 4.7k
GND -> GND
My sensor init part of code learnt from https://github.com/BoschSensortec/BHY2-Sensor-API :
#include "bhi260ap/BHI260AP.fw.h"
int sensor_BHI260AP_init()
uint8_t chip_id = 0;
uint8_t product_id = 0;
uint16_t version = 0;
int8_t rslt;
struct bhy2_dev bhy2;
uint8_t hintr_ctrl, hif_ctrl, boot_status;
#ifdef BHY2_USE_I2C
intf = BHY2_I2C_INTERFACE;
#else
intf = BHY2_SPI_INTERFACE;
#endif
//setup_interfaces(true, intf); /* Perform a power on reset */
#ifdef BHY2_USE_I2C
rslt = bhy2_init(BHY2_I2C_INTERFACE, (bhy2_read_fptr_t) platform_twi_read, (bhy2_write_fptr_t) platform_twi_write, (bhy2_delay_us_fptr_t) platform_delay_us2, BHY2_RD_WR_LEN, NULL, &bhy2);
#else
rslt = bhy2_init(BHY2_SPI_INTERFACE, (bhy2_read_fptr_t) platform_spi_read, (bhy2_write_fptr_t) platform_spi_write, (bhy2_delay_us_fptr_t) platform_delay_us2, BHY2_RD_WR_LEN, NULL, &bhy2);
#endif
print_api_error(rslt, &bhy2);
rslt = bhy2_soft_reset(&bhy2);
rslt = bhy2_get_chip_id(&chip_id, &bhy2);
/* Check for a valid chip ID */
if ((chip_id != 0x70) && (chip_id != 0xF0))
printf("CHIP ID read %X. Expected %X\r\n", chip_id, BHY2_PRODUCT_ID);
else
printf("BHI260/BHA260 found. CHIP ID read %X\r\n", chip_id);
rslt = bhy2_get_product_id(&product_id, &bhy2);
/* Check for a valid product ID */
if (product_id != BHY2_PRODUCT_ID)
printf("Product ID read %X. Expected %X\r\n", product_id, BHY2_PRODUCT_ID);
else
printf("BHI260/BHA260 found. Product ID read %X\r\n", product_id);
/* Check the interrupt pin and FIFO configurations. Disable status and debug */
hintr_ctrl = BHY2_ICTL_DISABLE_STATUS_FIFO | BHY2_ICTL_DISABLE_DEBUG;
rslt = bhy2_set_host_interrupt_ctrl(hintr_ctrl, &bhy2);
/* Configure the host interface */
hif_ctrl = 0;
rslt = bhy2_set_host_intf_ctrl(hif_ctrl, &bhy2);
/* Check if the sensor is ready to load firmware */
rslt = bhy2_get_boot_status(&boot_status, &bhy2);
if (boot_status & BHY2_BST_HOST_INTERFACE_READY)
uint8_t sensor_error;
int8_t temp_rslt;
printf("Loading firmware.\r\n");
/* If loading firmware to flash, erase the relevant section */
#ifdef UPLOAD_FIRMWARE_TO_FLASH
if (boot_status & BHY2_BST_FLASH_DETECTED)
uint32_t start_addr = BHY2_FLASH_SECTOR_START_ADDR;
uint32_t end_addr = start_addr + sizeof(bhy2_firmware_image);
printf("Flash detected. Erasing flash to upload firmware\r\n");
rslt = bhy2_erase_flash(start_addr, end_addr, &bhy2);
else
printf("Flash not detected\r\n");
return 0;
#endif
rslt = bhy2_upload_firmware_to_ram(bhy2_firmware_image, sizeof(bhy2_firmware_image), &bhy2);
temp_rslt = bhy2_get_error_value(&sensor_error, &bhy2);
if (sensor_error)
printf("%s\r\n", get_sensor_error_text(sensor_error));
print_api_error(temp_rslt, &bhy2);
printf("Booting from Flash.\r\n");
rslt = bhy2_boot_from_flash(&bhy2);
#else
printf("Booting from RAM.\r\n");
rslt = bhy2_boot_from_ram(&bhy2);
#endif
if (sensor_error)
rslt = bhy2_get_kernel_version(&version, &bhy2);
if ((rslt == BHY2_OK) && (version != 0))
else
printf("Host interface not ready. Exiting\r\n");
//close_interfaces(BHY2_SPI_INTERFACE);
return 0;
return rslt;
