BHI360
Dear Team,
I have successfully built the sample SDK example from BHI360_SDK_1.1.18.2_rc7 and generated the firmware image.
I would like to understand the expected functionality of this firmware. Specifically, could you please clarify:
  • What is the intended purpose of this sample application?
  • What sensor features or algorithms are enabled in this build?
  • What output data should I expect after flashing this firmware onto a BHI360 Shuttle Board?
  • Are there any specific host commands or interfaces required to observe the expected output?
  • Is the output available through I2C, UART, or another communication interface?
For my setup, I am not using the Application Board. Instead, I am using a custom board and transferring the firmware to the BHI360 device over I2C. I would like to verify whether any additional configuration is required and what behaviour or output I should expect after the firmware is loaded.
Any documentation or guidance regarding the functionality of this sample firmware would be greatly appreciated.
Thank you for your support.
Sensor
BHI360
Application
Wearables
Development Platform
Renesas RA6E2
Label
BHI360
