BHI360+BMM350 firmware error (0x22)
I am trying to use latest firmware(Bosch_Shuttle3_BHI360_BMM350C.fw) based on SDK 1.1.18 to use on our custom hardware board which is similar to shuttle board design but after loading firmware I get "[Sensor error] Sensor Init Failed: No Response from Device" error. I am using Euler example under github repository as reference. I tested the "Bosch_Shuttle3_BHI360.fw" and it seems it doesn't show same error and it loads correctly.
Also I don't see any issue for BHI360+BMM350 firmware built on SDK 1.1.16 as it loads without problem
Could you please help with this issue?
Thanks
