Hi, I found this in the documentation "The BHI360 provides various sources, which can generate Fuser2 interrupts. In this section, the Fuser2 interrupt
mechanisms are described.
The interrupt handlers are managed by the Event-Driven Software Framework and therefore there is typically no need
for the user to interact with them directly.
However, for cases where the user needs to extend the system, e.g. by connecting an additional external device (e.g.
a sensor) or a signal (e.g. a camera shutter interrupt for time synchronization), additional interrupt handlers need to be
installed. The SDK provides a method for this in form of the physical sensor driver, which integrates such extensions into the
overall framework in a smooth way."
Is there a BHI360 driver example for camera shutter interrupt for time synchronization?
Many thanks Cozmo
