Can you please tell me the INT1/INT2 Output Characteristics of BMA253?
I looked through the datasheet but could not find the information in the datasheet.
How much does the INT1/INT2 Output pin sink current when the output is set to Low '0'.
I have the below situation:
BMA253 is communicating with a master device by I2C.
I2C bus is connected and pulled-up by 10kohm.
BMA253 INT1 is connected to the master device GPIO and the Input pin is pulled-up internally with 25kohm resistor. (By mistake I have set the pin to Input pull-up)
BMA253 INT2 is connected to the master device GPIO and the Input pin is pulled-down internally with 25kohm resistor.
BMA253 INT1 and INT2 is active '1'
So normally when the interrupt doesn't occur the INT1/INT2 output is set to Low '0'.
Thank you.
