BMA253 interrupt threshold
I am using BMA253.
I want to output an interrupt using a high-G interrupt.
The board is usually vertical.
High_en_z, high_en_x interrupts are activated.
A high-G interrupt is output by tilting the board from the above state.
The angle I want to detect is 45 degrees and the acceleration is 0.707G.
Since it is set to the 4G range, the threshold value (address 0x26) is Expect it to work correctly in 0x2D.
However, the interrupt occurs at a smaller threshold value (0x23).
Does anyone know the cause and countermeasures?
