BMA280 Fifo in Low power mode.
I'm designing a battery powered device wit BMA280. So, I hope to use Low power modes with FIFO.
The operation sequence I'm testing is like this.
1. Constantly monitoring vibration in LPM1. In this time,  slope interrupt is mapped interrupt pin1.
2. If some movement is detected, disables interrupt 1 and starts using FIFO with a equidistance mode.
    In this time, changes mode to  LPM2 to get data from FIFO_DATA (0x3F) and  enables watermark interrupt mapped to interrupt pin2.
   Actually, I set to Normal mode before going LPM2 from LPM1.
3. Fetching data from Fifo for a while.
4. After then, goes back to LPM1 again, enables interrupt 1, and disable interrupt 2.
But, unfortunately, I found that Fifo is not filled when I change mode from LPM1 to Normal in step 2 above.
The only way I can make queue operation again is applying softreset.
If I block codes to change modes, it correctly fills FIFO and invokes watermark interrupt (pin2)
Am I using BMA280 correctly? Is there any command to run FiFo filling operation while I'm changing modes?
Thanks,
Best reply by FAE_CA1
Yes, your understandings are correct for BMA280. Please switch to BMA456 that has intenral time stamp and 1KB FIFO size.
