Are there any startup guides for this exact combination? The existing BMA400 guide is for application board 2.0. Is there a newer guide somewhere?
I am able to connect via USB and start streaming of BMA400 data, however, it seems some config settings relating to interrupt config and auto low-power / wake-up features (are not working quite right or the UI has invalid interactions with hardware, I'm not sure).
Before I start regurgitating obtuse details of failures, I am wondering if there are some required firmware or other updates for this hardware combination to work without glitch.
My purpose is just to rapidly confirm configuration settings and behavior as we are using the BMA400 on a custom product board and need to confirm behaviors (to decouple any BMA400 issues from our custom main board).
Also, the Development Desktop 2.0 software does not actually save sensor settings (no file is actually saved to hard drive), so I have to manually set stuff every start. Is this a known problem & is there a fix? I am running on Win10 and even ran as administrator to make sure no file access issues.
If there are any 1..2..3.. basics of this Bosch ecosystem I'm all ears, this is my first time messing with these dev boards / tools from them so would like to move past any startup-gotchas ASAP.
Thanks,
John @ Orthocare
